#466 Post by MartyMcNuts » Wed Feb 19, 2020 5:29 am
AndWhi wrote:
Tue Feb 18, 2020 11:56 pm
I'm having difficulties with the flasher on my External LG BP50NB40 NB50 1.01 on a Win10 Pro system.
The flasher shows error #5 when I try to use the DE_LG_BP50NB40-NB50_1.01_MK_HBD.bin file. What am I doing wrong here? :?
From my OP:
"Firmware BP60NB10_1.00_MK_HBD will allow you to flash your BP50NB40 to BP60NB10. Firmware BP50NB40-NB50_1.01_MK_HBD will allow you to go back to BP50NB40_1.01_MK if you ever require it."
You are trying to flash the wrong firmware. You should be trying to flash BP60NB10_1.00_MK_HBD.
If you are not successful, try flashing plain old BP50NB40_NB50_1.01-MK first, then flash the HBD firmware.
AnOctathorp
#467 Post by AnOctathorp » Thu Feb 20, 2020 12:10 am
Billycar11 wrote:
Wed Feb 12, 2020 8:55 pm
RocketRobz wrote:
Wed Feb 12, 2020 6:07 am
Hello! I need help.
I bought a WH16NS40-NS50 drive, and comes with firmware 1.04.
I'm trying to flash firmware 1.02 on it, but I'm getting "Updating Failure #4", when I try to do it with the modified ASUS flasher.
I also tried 1.03, but I got the same message.
Read this https://www.makemkv.com/forum/viewtopic.php?f=1&t=1067
That link brings me to a generic news and announcements page. I'm currently receiving a Failure #4 while using the Modified Asus Flasher on my ASUS BW-16D1HT 3.10 down to 3.02.
Any advice?
#468 Post by Billycar11 » Thu Feb 20, 2020 1:28 am
Any advice?
Oops here the right one https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Cyberpower678
#469 Post by Cyberpower678 » Mon Feb 24, 2020 12:54 am
I get update error number 4 when trying to flash my WH16NS40 with SVC NS50 from 1.0.4 to 1.0.2. Please advise.
Cyberpower678
#470 Post by Cyberpower678 » Mon Feb 24, 2020 2:29 am
Also I have an older unit with same model, but with SVC Code NS40 and revision 1. It was manufactured in June 2015. Can anyone tell me if the unit itself is capable of UHD as it appears to not recognize UHD discs at all. It just seeks endlessly.
#471 Post by MartyMcNuts » Mon Feb 24, 2020 3:02 am
Flash 1.04-MK first. You cannot go straight from 1.04 to 1.02.
jonghotti
#472 Post by jonghotti » Mon Feb 24, 2020 3:24 am
Here’s a question: I’ve got DVD Fab complaining about a flashed ASUS saying it needs to have its firmware downgraded. I originally flashed it to 3.10 MK which I assume I
is the problem. So what would be a good firmware version to use to avoid upsetting DVD Fab?
Thank you.
#473 Post by MartyMcNuts » Mon Feb 24, 2020 3:29 am
Thank you.
https://www.dvdfab.cn/4k-uhd-drives.htm
According to their website, it appears it needs 3.01...
Try 3.02. I had someone ask me this same question earlier this morning!!
Cyberpower678
#474 Post by Cyberpower678 » Mon Feb 24, 2020 3:30 am
1.04-MK doesn't actually seem to exist. Am I overlooking something here?
jonghotti
#475 Post by jonghotti » Mon Feb 24, 2020 3:52 am
Thanks for the quick answer Marty.
jozor
#476 Post by jozor » Mon Feb 24, 2020 9:31 am
Hello after trying to change firmware on my LG bh16ns40 (because wrong Blue-Ray recording) using this flasher : BH14NS40_N1.00-A4_patched and this firmware: DE_flash_HL-DT-ST_BD-RE_BH16NS40_1.02_NS50 both downloaded from this website, my optical drive does not recognize any medium :_(( I am try to record another firmware, but still is no able to read media:_((
please, advice me , what to do?
#477 Post by Woodstock » Mon Feb 24, 2020 1:43 pm
Not NS50 or later: No UHD
Cyberpower678
#478 Post by Cyberpower678 » Mon Feb 24, 2020 2:11 pm
Okay. I managed to roll it back by flashing a different drive FW on there and then flashing the actual model number to 1.02. It's reading UHD discs now. Quick question got a FW that you recommend in terms of speed and reliability for this model? This FW seems, slow.
#479 Post by MartyMcNuts » Mon Feb 24, 2020 10:03 pm
Basically the UHD firmwares read at 4x to 6x. The only firmware that is faster belongs to the official UHD drive, the WH16NS60 which reads at 6x to 8x.
FanaTekTech
#480 Post by FanaTekTech » Tue Feb 25, 2020 12:07 am
Hello, I tried to use your tool to downgrade my LG BH16NS55 1.03 to 1.02.
I got an "Access denied" error !
************** Texte de l'exception **************
System.ComponentModel.Win32Exception: Accès refusé
à System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
à System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
à FW_Changer_for_UHD_Friendly_Drives.Form1.RunNewEXE()
à System.Windows.Forms.Form.OnLoad(EventArgs e)
à System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
à System.Windows.Forms.Control.CreateControl()
à System.Windows.Forms.Control.WmShowWindow(Message& m)
à System.Windows.Forms.Control.WndProc(Message& m)
à System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
à System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assemblys chargés **************
mscorlib
Version de l'assembly : 2.0.0.0
Version Win32 : 2.0.50727.9148 (WinRelRS6.050727-9100)
CodeBase : file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
ASUS_ODD_FW_Changer_(Modified)
Version de l'assembly : 1.0.0.0
Version Win32 : 1.0.0
CodeBase : file:///C:/Users/util2/Downloads/(Modified)%20ASUS%20ODD%20FW%20Changer%20(24.08.2019)%20+%20UHD%20Friendly%20Firmwares%20%20+%20Latest%20MK%20Pack%20(14.02.2020)/ASUS_ODD_FW_Changer_(Modified).exe
Version Win32 : 2.0.50727.9136 (WinRelRS6.050727-9100)
CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Version Win32 : 2.0.50727.9147 (WinRelRS6.050727-9100)
CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Core
Version de l'assembly : 3.5.0.0
Version Win32 : 3.5.30729.9135 built by: WinRelRS6
CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Windows.Forms.resources
CodeBase : file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fr_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
My configuration is (Maybe not a problem but it's an information !):
Windows 10 Pro 64bits
Some stuffs for developer (Visual Studio 2019 Community and others)
HL-DT-ST BD-REBH16NS55 1.03
PIONEER BD-RWBDR-211M 1.02
I have AnyDVD HD in my system too and my firewall has been dropped to trying it.
Thank you for this tool (maybe it works for me in the future) !
Happy coding !
Win 10 Pro 64bits / 32GB RAM / 30To / Fiber optic / RTX 2080 super on 4K Samsung TV
French Active Fansubber / Enthousiast Developer (Java, C# and others)
Has "World Community Grid" running on PC
