Has there been any progress on MOULIN ROUGE or ROMEO + JULIET? I just emailed the SVQ files for both to try and help the cause. The updated files mentioned above definitely do not work for these two titles at present.
Any updates would be appreciated. Very anxious to backup my copies of these two blurays...
Thanks.
John.
New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
john_nikkon
Re: New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
You were the first one to submit dumps for these particular editions. SVQ files were just updated.
john_nikkon
Thank you so so much. I tried it for both discs and it work perfectly!!! You guys rock.
John.
John.
JishanF
The Rocky Horror Picture Show 35th Anniversary Blu-Ray edition will not open either. I already submitted a dump but just wanted to post in case anyone else runs into this problem.
It should work, at least with manual dsall.svq download, see http://www.makemkv.com/forum2/viewtopic.php?f=5&t=612
JishanF
Thanks for the info. I downloaded the svq and lo and behold the disc opened! Thank you.
