Failed to save title 0 to file <Path>
manas
#1 Post by manas » Thu Oct 14, 2010 12:33 pm
I am not sure whether my original post http://www.makemkv.com/forum2/viewtopic ... 8269#p8269 was in the right forum. Hence adding the problem here as well.
The problem: I created a bluray image file (.img) of the clips I shot in my HD Camcorder by exporting it from FCP (actually choosing "Share as" option and clicking on hard drive for blu-ray image).
Steps followed for creating MKV.
1. Run MakeMKV.
2. Click on the Source
3. It allows me to select either /BDMV/index.bdmv or /BDMV/MovieOBject.bdmv. No other files are selectable as the "Source File". Irrespective of which file I chose, I always get this message:
MakeMKV v1.6.0 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/xxxxx/MakeMKV_log.txt
Optical drive "DVD+R-DL Optiarc DVD RW AD-7240S 1.03" opened in OS access mode.
Opening files on harddrive at /Volumes/TESTING_BLURAY!-BLU-RAY/
AACS directory not present, assuming unencrypted disc
DEBUG: Code 22 at qHl$nd&&\'~q8n(^_:29395103
DEBUG: Code 2 at fQM-tR[T1CDI}oJvob:121263038
File 00000.m2ts was added as title #0
File 00001.m2ts was added as title #1
File 00003.m2ts was added as title #2
Saving 1 titles into directory /Users/xxxxx/Movies/UNNAMED_DISC
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 7 at ML7guqhKk;owG;\JTr>*:121264050
DEBUG: Code 0 at o$RAsAp!bG*A&KNptG\;':29397449
DEBUG: Code 0 at g*_tFMoQkzW[<oWsU\$:121263751
Failed to save title 0 to file /Users/xxxxxx/Movies/UNNAMED_DISC/title00.mkv
0 titles saved, 1 failed
Please help to resolve or please point me in the right direct. Thanks in advance.
Regards
Manas.
setarip_old
Re: Failed to save title 0 to file <Path>
#2 Post by setarip_old » Thu Oct 14, 2010 8:30 pm
Hi!
Is it legitimate to include "!" or "-" in either file or directory names?
#3 Post by mike admin » Fri Oct 15, 2010 9:25 am
H.264 video is out of blu-ray spec.
manas
#4 Post by manas » Wed Oct 20, 2010 9:11 am
@setarip_old
I removed ! and -. Still ending up with same error!
@mike admin
I do not actually understand. Would you please expand it ?
#5 Post by mike admin » Fri Oct 22, 2010 8:03 am
manas wrote:I do not actually understand. Would you please expand it ?
It means that whatever software created this blu-ray image did it wrong. What software did you use to create such disc? Can you create a disc with a single 3-5 seconds clip?
manas
#6 Post by manas » Sun Oct 24, 2010 5:28 am
@mike_admin
Thanks Mike for the response. I used Final Cut Pro.
The original clip was shot in 1920x1080p 30fps H264 mode. I have created a small file - 9 sec long. I have uploaded the entire img file.
Normally, I choose the MovieObject.bdmv after mounting the img file (in Mac OS). MakeMKV scans and reports the number of tiles correctly. When I click on MakeMKV icon, it finally ends with the failed message. I am trying to have a MKV file with chapter control so that I can play it on my WDTV.
Thanks in advance Mike, again.
manas
#7 Post by manas » Tue Nov 02, 2010 2:03 pm
@mike_admin:
Any good news, Mike?
Thanks in advance.
#8 Post by mike admin » Sat Nov 06, 2010 10:03 am
Should be corrected in a new version.
