Ford vs Ferrari Errors.
Mondays
Post by Mondays »
Brand new disc. Getting 100s these errors, the fail. I tested other discs that I have ripped before and MKV works fine with them so I believe my BD drive is fine.
Anyone else having trouble with this disc? Maybe download of the files from hkdatastore.tk is not working? I am thinking that discs already ripped have the downloaded de-encryption files so they work.
The source file '/BDMV/STREAM/02886.m2ts' is corrupt or invalid at offset 21964800, attempting to work around
Hash check failed for file 02886.m2ts at offset 22013952, file is corrupt.
Error 'OS error - Access is denied' occurred while creating 'D:/MKV/Ford v Ferrari_t00.mkv'
Failed to save title 0 to file D:/MKV/Ford v Ferrari_t00.mkv
Encountered 1 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failed
jinx100
Re: Ford vs Ferrari Errors.
Post by jinx100 »
I had no problem with Ford v Ferrari Blu-Ray. Probably a bad disc.
Mondays
Post by Mondays »
Any chance that my computer is blocking the de-encryption files for the disk that MakeMKV pulls before ripping a disk? It used to pull from hkdatastore.tk or maybe hkdata.fairuse.org I set up an exception in firewall for makemkv downloads in malwarebytes
Grauhaar
Post by Grauhaar »
Mondays wrote:
Sat Feb 15, 2020 3:36 pm
No, if there a an decryption problem you see complete other errors. Your error says, that the stream file 02886.m2ts has a problem. Maybe the debug log (see my signature) gives more hints.
Good Luck :)
Mondays
Post by Mondays »
I exchanged for a new disk. Same errors.
Contacted Square trade and they are sending me out a $70 check.
The only thing I ever use a DVD for is nowadays is with Makemkv. They seem to crap out after ~2years so a $2.78 4 year warranty purchase is well worth it.
Type of coverage:
4 years Coverage
starts: 10/25/2018
Coverage ends: 10/25/2022
Care Plan Price: $2.78
Purchase Date: 10/20/2018
Purchased for: $2.78
Replacing an LG LG Electronics Blu-ray DVD Writer (UH12NS40)
with an ASUS BW-16D1HT
Ford vs Ferrari ripped no problem.
Something about MakeMKV must be hard on DVDs because I get 1 to 3 years out of them before they start throwing errors on rips. I think this is my 5th one over 10 years.
