King Kong UHD Bluray
Martin
#1 Post by Martin » Sat Feb 15, 2020 2:07 pm
i have a problem with my King Kong UHD Disc. Makemkv won´t backup the disc. There are several mistakes on the log.txt
How can i make this work?
Please help
Re: King Kong UHD Bluray
#2 Post by Woodstock » Sat Feb 15, 2020 3:05 pm
Without knowing what the errors are, there isn't a lot of help that can be offered.
Martin
#3 Post by Martin » Sat Feb 15, 2020 3:25 pm
MakeMKV_log.txt
these are the log files from the error(s)
(37.25 KiB) Downloaded 570 times
#4 Post by Woodstock » Sat Feb 15, 2020 4:11 pm
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00083.m2ts' bei Offset '5627768832'
002023:0000 Encountered 7 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=7 name=SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 1 unclassified errors
Probably a dirty disk; there are parts of it your drive cannot read. Cleaning will help.
Martin
#5 Post by Martin » Sat Feb 15, 2020 4:57 pm
i am sorry but i have cleaned the disc a few times now and it doesn´t help. it seems that the disc gets to a certain point and then stops
Martin
#6 Post by Martin » Sat Feb 15, 2020 6:08 pm
MakeMKV_log.txt
this is from the backup. Other discs goes without problems
(2.83 KiB) Downloaded 600 times
Martin
#7 Post by Martin » Sat Feb 15, 2020 6:10 pm
for me it looks like the drive couln´t read the stream 83 - but why and how can i clear that problem
