BP60NB10 Firmware Downgrade Error
Ventriloquist
Re: BP60NB10 Firmware Downgrade Error
Post by Ventriloquist »
Weekbump: Any luck with the test flash image? :)
Post by mike admin »
Here you go!
HL-DT-ST-BD-RE_BP60NB10-1.01-NM01801-211905031534.zip
(1.28 MiB) Downloaded 1116 times
Ventriloquist
Thanks, mike. Ripping a test disc now.
Let me know if there's anything in particular you need tested with the image.
Ventriloquist wrote:
Fri Feb 14, 2020 10:01 pm
Can you please confirm if the new 1.01-MK is UHD friendly or if a downgrade to 1.00 is required.
Ventriloquist
No downgrade appears to be required. (Mike didn't instruct me to, I didn't try. He's updated the firmware pack to include the 1.01-MK image as well.)
I'm on my 3rd UHD rip as I post this.
Sat Feb 15, 2020 2:00 am
Thanks for the confirmation!
copperjr
Post by copperjr »
mike admin wrote:
Fri Feb 14, 2020 5:24 pm
Here you go!
Hi Mike. I have tried everything. I have the LG External BP60NB10 and everytime i try to run the asus odd FW i get the error after it ejects. help!
copperjr wrote:
Tue Apr 20, 2021 12:02 am
Here you go!
Don't use the ASUS flasher. Use the newer SDFtool Flasher. Also, if your drive is new and has encrypted firmware 1.02, check "enc?" for the first flash.
1. If it has 1.02, flash 1.02-MK with enc checked. If it has 1.01, flash 1.01-MK without enc.
2. Flash 1.00-MK without enc.
