Secret Agent
#1
Post
by Secret Agent » Thu Oct 21, 2010 6:01 pm
Hi
I can't seem to rip Bluray disks although DVDs work just fine. This using version 1.6.2. I have tried four discs so far and all error with the same message.
I have an iMac (one of the last white ones with Intel Core 2 Duo) and an LG Bluray drive housed in an external enclosure. (LG CH08LS10 8x BD-ROM with DVD±RW & LightScribe SATA Blu-Ray Drive). This drive has been confirmed to work with MakeMKV by at least one user on the plex wiki (
http://wiki.plexapp.com/index.php/Blu_Ray_Rips)
When I try to rip BD I place this disc in the drive and it spins up but shows no information in the panel although it does pick up the disc name correctly. If I then click on the open disc button anyway it sits for a bit and then comes back with this:
MakeMKV v1.6.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/xxxxxx/MakeMKV_log.txt
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-85J FCQA" opened in OS access mode.
Optical drive "BD-ROM HL-DT-ST BDDVDRW CH08LS10 2.00" opened in OS access mode.
DEBUG: Code 1073741830 at rrB}@)bp]+_xS-|'9[:29395839
DEBUG: Code 1073741830 at rrB}@)bp]+_xS-|'9[:121261727
Error 'Posix error - Device not configured' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 2.00' at offset '524288'
Error 'Posix error - Device not configured' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 2.00' at offset '1048576'
DEBUG: Code 1073741830 at rrB}@)bp]+_xS-|'9[:121264579
Error 'Posix error - Device not configured' occurred while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 2.00' at offset '32768'
DEBUG: Code 0 at Hu0{;.]@u7.9t$N%Fvh:29393447
I have fired up Windows in Bootcamp and installed the software which came with the drive and set the region to B and updated to the latest firmware from the LG site.
Installing a trial version of AnyDVD on the Windows Bootcamp partition allows me to rip the disc perfectly although the Windows version of MakeMKV has the same errors as above. I'm not sure what else I need to do to make sure the drive is configured for MakeMKV. I would prefer to not have to use Windows as it's a bit of pain booting back and forth. Anyone got any ideas what I am doing wrong? Any help would be appreciated.
SA
Post
by mike admin » Fri Oct 22, 2010 8:11 am
Please post the debug log from windows version running in a bootcamp. It should be a bit different but difference is crucial. Thanks.
Secret Agent
#3
Post
by Secret Agent » Fri Oct 22, 2010 11:05 pm
Hi
OK. Not sure what I did but the behaviour was slightly different this time in Bootcamp. Disc goes in and it spends a good minute or two scanning the devices. The I click on the open disc button and it just sits there and does nothing. I gave up after about five minutes and clicked on the cancel button which had no effect. I had to power off the LG drive to get anything to happen. It then started filling up the log file as below:
Debug log started at Fri Oct 22 22:40:07 2010 , written by MakeMKV v1.6.2 win(x86-release)
Using 520320KB for read cache.
001005:0000 MakeMKV v1.6.2 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\xxxxxx/MakeMKV_log.txt
001003:0020 DEBUG: Code 3221225664 at KV&ObvDR%bo"q`9V:121264533
Application exited at Fri Oct 22 22:48:26 2010
I hope this is what you were after. Many thanks for your help so far.
SA
Post
by mike admin » Mon Oct 25, 2010 6:32 am
It's some sort of hardware problem with your drive, looks very much like a loose cable.
Secret Agent
#5
Post
by Secret Agent » Wed Oct 27, 2010 12:46 am
Sorry, that's my fault. When it was scanning the disc nothing was happening and eventually I could hear the disc stop spinning although the scanning process continued. Trying to cancel did nothing so I had to power down the drive to get it to do anything.
I will try and get a more accurate log.
For info I downloaded a test copy of Mac BluRayRipper Pro which ripped all the discs that didn't work with MakeMKV so I'm pretty sure the drive works fine. I still want to use MakeMKV though so will try and get some accurate logs for you.
Thanks for your help so far.
SA
