asus BW12B1St no power after flash
MrMcMuffinJr
Post by MrMcMuffinJr »
So I followed the instructions on https://www.makemkv.com/forum/viewtopic ... 16&t=18933 and now my drive is a paper weight. is there anything I can do? so I ran the updater clicked cancel and then start. The drive opened like it was supposed to but then an error came up on flasher and the drive dropped from windows. opened case and re-plugged the sata but still nothing, rebooted and still nothing. Please assist.
Re: asus BW12B1St no power after flash
MrMcMuffinJr wrote: Thu Feb 13, 2020 1:10 am So I followed the instructions on https://www.makemkv.com/forum/viewtopic ... 16&t=18933 and now my drive is a paper weight. is there anything I can do? so I ran the updater clicked cancel and then start. The drive opened like it was supposed to but then an error came up on flasher and the drive dropped from windows. opened case and re-plugged the sata but still nothing, rebooted and still nothing. Please assist.
What's the build date on the drive case?
BlueMac77
Post by BlueMac77 »
@MrMuffinJr. If the Asus drive was built before 2015 and flashing it may brick the drive.
MrMcMuffinJr
BlueMac77 wrote: Thu Feb 13, 2020 2:58 pm @MrMuffinJr. If the Asus drive was built before 2015 and flashing it may brick the drive.
it's 1.00 rn
MrMcMuffinJr
also...the drive shows up in bios and shows in dev mgr. after reboot but it has no finctionality
st4evr
Post by st4evr »
MrMcMuffinJr wrote: Fri Feb 14, 2020 3:45 am
it's 1.00 rn
Then yes, you just bricked your drive. Same as discussed here:
https://www.makemkv.com/forum/viewtopic ... ant#p72248
You needed to do more research/reading prior to jumping into flashing. There are dozens of examples and warnings throughout the forum of when not to do this. Including in the main drives guide:
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
The semi convoluted dosflash method may be the only way to recover it. Or the simpler solution of moving on and buy a new drive as advised on that same guide. Gotta pay attention and read.
