Grencola
Post by Grencola » Sun Feb 02, 2020 5:08 pm
bgalakazam wrote: Sun Feb 02, 2020 11:00 am
Grencola wrote: Sat Feb 01, 2020 5:55 pm who said anything about pirated movies?? A huge amount of people care about disc preservation where you watch it once or twice (or sometimes never even open it if it's a rare steelbook), and then just make a digital backup so you can view it to your hearts content without touching the physical copy. If you paid for the disc, you should be entitled to watch the backup in its full glory and not have choose between better picture or sound quality.
Let's be real here. The only reason there is so much interest in this is to pirate videos. I have YET to have a failed VHS, DVD, Bluray or UHD Bluray since I started using physical media in 1994. Don't even try to give me the argument of media preservation :roll: . And realistically, how many times are you going to watch a movie? By the time the media wears out (which it won't), 8K remasters will be here on newer media.
I strongly appreciate the work you and others are doing in regards to DV on local playback. But to say the driving factor is media preservation is simply not true. Also if you want media preservation... just rip and reburn the bluray. Or better yet if you want convenience of no disk, do what 99% of the population does and stream via Netflix, etc.
Sounds like we found the pirate :mrgreen: I'll remind you we are on makemkv's forum, a legitimate program used to convert your purchased physical media into a digital backup. This entire thread started because we were hoping to get Dolby Vision added into mkv's so that us responsible folks didn't have to make compromises while doing this. Also, I could make many other arguments too if you really want :P btw, a big component of media preservation is once people have ripped their collection to a harddrive, the convenience factor is huge. being able to scroll through a beautiful list with extra scraped info and playing what you want at a touch of a button vs having to get up and down and find the case and open it up, and hope it's right, and insert/eject discs is ridiculous in 2020. You said if I want this convenience then to watch Netflix?! Seriously? That's surely worse than having to decide between dolby vision or hd-audio, as it's all lossy compressed garbage that, except for original content, is old and tiring.
Post by RESET_9999 » Sun Feb 02, 2020 7:08 pm
How we use the tools or what source do we use is irrelevant. In the end, all we want is the most convenient playback method at the highest quality possible.
ragico
Post by ragico » Sun Feb 02, 2020 8:17 pm
Of course nothing against netflix.
It's just a question of what we watch on our expensive tv's.
To me no comparison is possible between an original bluray 4k disc (with or without dolby vision) and the equivalent streamed by any of the streaming companies.
But, as usually, high quality is a niche: As for everything in this world.
StealMySoda
Post by StealMySoda » Mon Feb 03, 2020 6:34 pm
JonathanX64
Post by JonathanX64 » Sun Feb 09, 2020 8:41 pm
Hello! I have two questions about Dolby Vision muxing process.
Some users on this thread reported that dual layer mp4 works with Sony UBP-X700 players, and with LPCM 7.1 sound. How exactly have you prepared files for the playback? Have you used DVDfab or other software? Have you converted TrueHD stream to LPCM, and if so, how that was done?
I also have a question about mp4muxer tool from the first post in this thread. Does it allow converting dual layer DV to single layer? If so, how exactly it is done? I've tried it on Windows, Linux and Mac, and it never delivers the results. The tool always fully reads through the supplied files (~60 gigs in my case), it writes ~600 megabytes of output file (equals to the size of supplied .ac3 track), and then it just freezes. Has it worked for anyone?
Thanks.
jaanus
Post by jaanus » Mon Feb 10, 2020 2:43 pm
daddy wrote: Mon Jan 27, 2020 6:27 pm I think the Sony dv support is the worst.
http://4k.com/news/sony-explains-about-dolby-vision-problem-in-its-4k-hdr-tvs-partly-blames-others-23168/ wrote:Sony implemented a modification to Dolby Vision support by which most of the processing for playback of content with this kind of high dynamic range formatting is offloaded to the device from which it came from instead of being done inside the TV itself. Thus the need for complementary updates from streaming device makers. Why Sony chose this approach is still unknown but it could be because they wanted to make their Dolby Vision update as lean and easy to implement as possible.
Philips 804 is an android tv with a built-in Video player that can handle dual layer dv.
This is surprising that nobody tried to backup this android application, to try it on another android device :idea:
Hi
Do you know more about Philips 804 dual layer DV capability?
Or any link ?
Can't get mine working. Incorrect colours or unsupported format message. Single layer is ok.
BR,
Jaanus
Post by RESET_9999 » Mon Feb 10, 2020 11:38 pm
JonathanX64 wrote: Sun Feb 09, 2020 8:41 pm Hello! I have two questions about Dolby Vision muxing process.
Thanks.
Hi, i do all my mp4 dual layer remux with:
demuxing video and audio LPCM7.1:
ffmpeg.exe -i X:\bluray.m2ts -map 0:0 -c copy X:\HDR10.hevc -map 0:1 -c copy X:\DV.hevc -map 0:2 -c:a pcm_s24le -ar 48000 -rf64 auto X:\lpcm.mov
dual layer mp4 muxing:
mp4muxer_64bits.exe --dv-profile 7 --input-file X:\HDR10.hevc --input-file X:\DV.hevc --output-file DV-MP4-nosound.mp4
adding LPCM 7.1 audio:
mp4box.exe -add X:\DV-MP4-nosound.mp4:rate=0 -add X:\lpcm.mov#audio:lang=en-EN -tmp X:\ -brand mp42isom -ab dby1 -no-iod X:\DV-MP4-7.1.mp4
98% of the DV movies play fine on the X700 using these tools. you can find the tools here:
https://mrmc.tv/forum/viewtopic.php?f=1 ... &start=310
deadchip12
Post by deadchip12 » Wed Feb 12, 2020 7:10 pm
It is not advisable to demux both base layer and dolby vision layer at the same time right? As in we need to demux those one by one instead? I did that with Hellboy 2019 and it got massive stutter during playback.
Post by RESET_9999 » Wed Feb 12, 2020 10:44 pm
deadchip12 wrote: Wed Feb 12, 2020 7:10 pm It is not advisable to demux both base layer and dolby vision layer at the same time right? As in we need to demux those one by one instead? I did that with Hellboy 2019 and it got massive stutter during playback.
No issue on my end. I always demux both video layers and audio in one step. Hellboy 2019 played perfectly fine with the x700.
deadchip12
Post by deadchip12 » Thu Feb 13, 2020 9:44 am
RESET_9999 wrote: Wed Feb 12, 2020 10:44 pm
Maybe it’s the issue with my hard drive. I will try moving the film to another hard drive. Is it ok to run the demuxing on an external hard drive? Is there any chance the hard drive will break because of that? I’m asking because my previous hard drive broke and the new one starts showing sign of slowness and I ran demuxing on both.
Post by RESET_9999 » Thu Feb 13, 2020 12:03 pm
deadchip12 wrote: Thu Feb 13, 2020 9:44 am Maybe it’s the issue with my hard drive. I will try moving the film to another hard drive. Is it ok to run the demuxing on an external hard drive? Is there any chance the hard drive will break because of that? I’m asking because my previous hard drive broke and the new one starts showing sign of slowness and I ran demuxing on both.
I do all my remux on an internal NVME m2 PCI-E drive because of the amazing speed and use a fast external USB 3.0 SSD drive for playback but I've experienced data writing issues with some cheap external USB enclosure. So yeah it could be a problem.
deadchip12
Post by deadchip12 » Thu Feb 13, 2020 12:31 pm
RESET_9999 wrote: Thu Feb 13, 2020 12:03 pm
Funnily enough, the hard drive with the issue here is a newer one with usb 3.0, while the one without issue is pretty old with only usb 2.0 I believe.
davin8r
Post by davin8r » Thu Feb 20, 2020 4:27 am
Has anyone else tried just ripping the main movie file (using MakeMKV or DVDFab 11) and playing that on the Sony x700? I've tried it on 2 UHD BluRays so far, and the x700 plays the movie file in both Dolby Vision *and* Atmos at the same time. Why bother to even convert to a different file container?
bgalakazam
Post by bgalakazam » Thu Feb 20, 2020 2:29 pm
davin8r wrote:Has anyone else tried just ripping the main movie file (using MakeMKV or DVDFab 11) and playing that on the Sony x700? I've tried it on 2 UHD BluRays so far, and the x700 plays the movie file in both Dolby Vision *and* Atmos at the same time. Why bother to even convert to a different file container?
You have to manually enable DV on the X700. It will display as such on the tv, but not be it necessarily. If you play back the same file from the tv chances are there is no DV trigger. Also, X700 cannot play Atmos from MKV TrueHD track.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
Post by SamuriHL » Thu Feb 20, 2020 2:53 pm
bgalakazam wrote: Thu Feb 20, 2020 2:29 pm
They're not talking about MKV. They're talking about leaving it in an m2ts file. I've wondered the same thing if it'd work or not but not enough to pull the x700 out of the other room to test it. The internal player on the tv doesn't support m2ts playback at all.
