Can't Rip Judy
DukeD
Can't Rip Judy
#1 Post by DukeD » Wed Feb 12, 2020 9:33 pm
First time I have been totally stymied. A number of large files, tried each one, none worked. Anyone else have this problem with this disk? Using Win 10 64 bit. Ver 1.14.17 of Make MKV
Re: Can't Rip Judy
#2 Post by Woodstock » Thu Feb 13, 2020 3:58 am
"none worked"
Some hints would be nice, like what error messages you received.
If it's a Lionsgate title, there will be ONE working title, but they screw up the directory pretty bad to make it hard to find some times.
DukeD
Re: Can't Rip Judy
#3 Post by DukeD » Thu Feb 13, 2020 11:35 am
Thanks for your time to address this, I appreciate it.
When I open MKV and have it open the disk, it says
MakeMKV v1.14.7 win(x64-release) started
Title #1 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #5 was added (16 cell(s), 1:56:16)
Title #6 was added (4 cell(s), 0:09:34)
Title #9 was added (1 cell(s), 0:04:03)
Title #10 has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 was added (18 cell(s), 2:03:03)
Title #23 was added (16 cell(s), 1:56:27)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 18-18 were removed from title end
Title #24 was added (16 cell(s), 1:58:09)
Title #25/0/2 was added (2 cell(s), 0:13:02)
Title #26 was added (16 cell(s), 1:58:09)
Title #27 was added (16 cell(s), 1:56:28)
Title #28 was added (16 cell(s), 1:58:09)
Title #29 was added (16 cell(s), 1:56:10)
Title #30 was added (16 cell(s), 1:58:09)
Title #32 was added (18 cell(s), 2:03:03)
Title #33 was added (18 cell(s), 2:03:03)
Title #34 was added (18 cell(s), 2:03:03)
Title #35 was added (16 cell(s), 1:58:09)
Title 1 in VTS 17 is equal to title 1 and was skipped
Title 1 in VTS 19 is equal to title 1 and was skipped
And it displays 8 files including 6 that are in excess of 5gb with 16 chapters each. Of course I expect that one of these is the title I'm interested in.
When I try the first one, it runs for in excess of 10 mins and the bars fill about 1/4" green and never advance further, nothing happens and , thus, no error codes or messages. Really perplexing. This same thing happens when I try the 7 other +5 gb files.
Your thoughts? Any further info I might supply to help?
Jeff-Mich
Re: Can't Rip Judy
#4 Post by Jeff-Mich » Tue Feb 18, 2020 11:09 pm
I'm seeing exactly the same thing... I tried all 5 of those 16 chapter titles which varied in size... none interestingly matching the 1:58:12 play time when playing in VLC
In all cases it writes just 4k to the output file and then just seems to hang (though I can abort).
I tried on two different PC's, one Win8 other Win10
Also probably not coincidental VLC also acts oddly... when playing the disc in VLC it goes straight to playing the movie... I can't get to the menu(s)... though I can in PowerDVD
Guess I'll be watching this movie tonight w/DVD player!
d_virtual_one
Re: Can't Rip Judy
#5 Post by d_virtual_one » Wed Feb 19, 2020 3:30 pm
Have the same problem as everyone else.
When using a DVD player seems to play title 35 correctly.
conchshell
Re: Can't Rip Judy
#6 Post by conchshell » Tue Apr 07, 2020 2:57 am
A quick search on "Judy" here led me to this post. I can confirm that [U.S.A Retail PLAYLIST = 00661.MPLS] was the correct playlist on my non-4K Blu-ray disc.
