Midway
Re: Midway
Thanks - this is just what I needed - MakeMKV Java routine picked the wrong source file.
ChrisCaPWN
Re: Midway
I manually went through to find the correct playlist for rental discs. I found it to be 00741.mpls.
Enjoy.
Enjoy.
- Midway Playlist.PNG (4.86 KiB) Viewed 90497 times
Re: Midway
I've got the UHD disc - neither MPLS is available. I can say the first 373 - bombed out at 38 minutes in - haven't seen that before. Testing the next one shortly
mkvman1000
Re: Midway
I rented the Redbox version and neither 00539.mpls or 00741.mpls were even on the disc. I also couldn't find a playlist with the same segment map as in the screenshot. Anybody have any ideas?
Re: Midway
My Redbox rental has both and 741 matches the map shown above. Have not watched the movie, but quick testing shows opening scenes and ending credits look correct.mkvman1000 wrote: Tue Feb 18, 2020 9:34 pm I rented the Redbox version and neither 00539.mpls or 00741.mpls were even on the disc. I also couldn't find a playlist with the same segment map as in the screenshot. Anybody have any ideas?
Are you getting a big list of mpls selections on your disc?
-Bill
mkvman1000
Re: Midway
Hmmm weird, and yeah there's a huge list.wmcclain wrote: Tue Feb 18, 2020 9:38 pmMy Redbox rental has both and 741 matches the map shown above. Have not watched the movie, but quick testing shows opening scenes and ending credits look correct.mkvman1000 wrote: Tue Feb 18, 2020 9:34 pm I rented the Redbox version and neither 00539.mpls or 00741.mpls were even on the disc. I also couldn't find a playlist with the same segment map as in the screenshot. Anybody have any ideas?
-Bill
Re: Midway
Thinking... is it the correct title? Redbox also has Dauntless: The Battle Of Midway, although it is DVD-only where I am. Don't know about nationally.
-Bill
mkvman1000
Re: Midway
It's Midway in 4K. This other thread https://www.makemkv.com/forum/viewtopic ... 12&t=21505 says another program found #504 to be the correct playlist, this disc does have that one so I'm trying it. Also interestingly all my playlists have 7 numbers for segment map rather than 10.wmcclain wrote: Tue Feb 18, 2020 10:01 pmThinking... is it the correct title? Redbox also has Dauntless: The Battle Of Midway, although it is DVD-only where I am. Don't know about nationally.
-Bill
Re: Midway
Ok, I don't follow UHD ripping closely but I would expect those discs to have different playlists than Blu-rays. So this is the wrong forum for your rental.mkvman1000 wrote: Tue Feb 18, 2020 10:04 pm It's Midway in 4K. This other thread https://www.makemkv.com/forum/viewtopic ... 12&t=21505 says another program found #504 to be the correct playlist, this disc does have that one so I'm trying it. Also interestingly all my playlists have 7 numbers for segment map rather than 10.
-Bill
mkvman1000
Re: Midway
dohwmcclain wrote: Tue Feb 18, 2020 10:08 pmOk, I don't follow UHD ripping closely but I would expect those discs to have different playlists than Blu-rays. So this is the wrong forum for your rental.mkvman1000 wrote: Tue Feb 18, 2020 10:04 pm It's Midway in 4K. This other thread https://www.makemkv.com/forum/viewtopic ... 12&t=21505 says another program found #504 to be the correct playlist, this disc does have that one so I'm trying it. Also interestingly all my playlists have 7 numbers for segment map rather than 10.
-Bill
Re: Midway
RedBox Version
Procmon verified
Title information
Source file name: 00741.mpls
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Segment map: 507,501,509,502,504,510,508,506,503,505
File name: Midway_t168.mkv
Procmon verified
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
PrideOfPR7
Re: Midway
One more to confirm this is the correct file.Dustin66 wrote: Tue Feb 18, 2020 11:21 pm RedBox Version
Procmon verified
Title information
Duration: 2:18:24
Chapters count: 16
Segment count: 10
Re: Midway
Any update on this? did #504 work for you?mkvman1000 wrote: Tue Feb 18, 2020 10:04 pmIt's Midway in 4K. This other thread https://www.makemkv.com/forum/viewtopic ... 12&t=21505 says another program found #504 to be the correct playlist, this disc does have that one so I'm trying it. Also interestingly all my playlists have 7 numbers for segment map rather than 10.wmcclain wrote: Tue Feb 18, 2020 10:01 pmThinking... is it the correct title? Redbox also has Dauntless: The Battle Of Midway, although it is DVD-only where I am. Don't know about nationally.
-Bill
