Jay and silent bob reboot correct playlist
omk1980
#1 Post by omk1980 » Thu Jan 23, 2020 7:05 pm
Anybody have the right playlist for this DVD? only seeing threads for the bluray copy.
Volkmeer
Re: Jay and silent bob reboot correct playlist
#2 Post by Volkmeer » Thu Jan 30, 2020 10:31 pm
Any luck with this one?
omk1980
#3 Post by omk1980 » Wed Feb 05, 2020 1:09 pm
No, how about you?
ffgoas
#4 Post by ffgoas » Wed Feb 05, 2020 5:30 pm
Title 60 worked for me. Had to select manually.
omk1980
#5 Post by omk1980 » Wed Feb 05, 2020 9:41 pm
Awesome. Thanks!
omk1980
#6 Post by omk1980 » Mon Feb 10, 2020 9:46 pm
not seeing 60. I've got 57, 58, 59, 61, 63. I'll try 58. What was the exact length of playlist 60? thanks for your help
ffgoas
#7 Post by ffgoas » Tue Feb 11, 2020 9:35 pm
You have to open the dvd manually. You can then select 60 and list the chapters.
ffgoas
#8 Post by ffgoas » Tue Feb 11, 2020 9:41 pm
if you select 57, 58 ,59 and then 61 you can see what files it is opening. Did the same for me. As MKV is opening the disc you will see 60 has some error. That is why it does not show up in the menu.
ffgoas
#9 Post by ffgoas » Tue Feb 11, 2020 9:44 pm
It was "open dvd file manually" or "open disc" in the files menu.
omk1980
#10 Post by omk1980 » Tue Feb 11, 2020 11:30 pm
Gotcha. that's wild. never done that before. backing up now. thanks again
