braveh
Re: Ultimate UHD Drives Guide Updated 2019
I read about LG WH16NS40 as being good for bluray ripping if firmware gets downgraded. But I can't seem to find that model. Instead, I can find LG BH16NS40 - is this model any good?
Or what other models are most reliable?
In my experience of 300+ drives the bu40n is the most reliable. The bh16ns40 is fine if it gets no read errors it's the same as the wh16ns40 just the boxes versionbraveh wrote: Sun Feb 09, 2020 10:25 pm I read about LG WH16NS40 as being good for bluray ripping if firmware gets downgraded. But I can't seem to find that model. Instead, I can find LG BH16NS40 - is this model any good?
braveh
by bu40n you mean LG BU40N, which is a laptop blu-ray drive?
does it require to have a certain SVC code or something else very specific, like it is suggested here in the case of the BH16NS40 - https://www.myce.com/news/the-ultimate- ... ive-83254/ ?
yes its a slim drive nope all bu40ns are compatible it natively supports UHD disks and has no sleepbug so you can rip and play UHD discs officially and unofficiallybraveh wrote: Mon Feb 10, 2020 9:21 pm by bu40n you mean LG BU40N, which is a laptop blu-ray drive?
wag12wag12
Hi, I also have a CH12NS40 , where can I find information on how to do this patch to enable 4K read?
Sodapop74
I tried "CSL – USB 3.0 SSD/SATA Adaptor Converter for SSD SATA 1/2/3 2.5 Inches (6.35 cm) HDD 3.5 SATA Drive (HDD/SSD) USB Attached SCSI Protocol (UASP) including mains adaptor" from Amazon.de but it didn't work with otical disc drives. Are there any simple SATA to USB adapters under say 20 euros on Amazon.de that would work or do I need to get a more expensive enclosure?
Here is a link to the one I bought: https://www.amazon.de/dp/B01K22TZ3I
JavierAlbadalejo
Hello, I have an ASUS BW-16D1HT with firmware 3.10.
Can anyone remote control assist me or something to do this? And how to do it fixing the sleep bug?
st4evr
There is a subforum dedicated to these services and which is also noted in the first post. Pay attention and read the guides/instructions/subforums. For these types of services, see here:JavierAlbadalejo wrote: Sun Feb 16, 2020 2:03 am Hello, I have an ASUS BW-16D1HT with firmware 3.10.
https://www.makemkv.com/forum/viewforum.php?f=20
And use their appropriate contact information.
JavierAlbadalejo
Thank you and my apologies for the problem.st4evr wrote: Sun Feb 16, 2020 2:07 amThere is a subforum dedicated to these services and which is also noted in the first post. Pay attention and read the guides/instructions/subforums. For these types of services, see here:JavierAlbadalejo wrote: Sun Feb 16, 2020 2:03 am Hello, I have an ASUS BW-16D1HT with firmware 3.10.
Read the first post of this very thread.Sodapop74 wrote: Tue Feb 11, 2020 11:02 pm I tried "CSL – USB 3.0 SSD/SATA Adaptor Converter for SSD SATA 1/2/3 2.5 Inches (6.35 cm) HDD 3.5 SATA Drive (HDD/SSD) USB Attached SCSI Protocol (UASP) including mains adaptor" from Amazon.de but it didn't work with otical disc drives. Are there any simple SATA to USB adapters under say 20 euros on Amazon.de that would work or do I need to get a more expensive enclosure?
Sodapop74
I did, but those aren't available in Europe. Ordering from the US means additional postage and customs charges and non-European power adapter. Does anyone have experience with Inateck's Unitek branded converter (https://www.amazon.de/dp/B00N4JLNXM)? It's advertised as being compatible with optical drives but so was the CSL one...
psycaz
Thank you to everyone for an easy to follow guide. Just purchased my WH16NS40 and changed the firmware no problem. Testing first disc and so far, all is great.
There are some bad reviews there. It appears to be a cheap copy with a dodgy power supply. We don't buy cheap junk. It's just not worth it. Better of spending a little more for a better quality one.Sodapop74 wrote: Mon Feb 17, 2020 12:28 am I did, but those aren't available in Europe. Ordering from the US means additional postage and customs charges and non-European power adapter. Does anyone have experience with Inateck's Unitek branded converter (https://www.amazon.de/dp/B00N4JLNXM)? It's advertised as being compatible with optical drives but so was the CSL one...
jonghotti
- Contact:
Here here!MartyMcNuts wrote: Tue Feb 18, 2020 3:42 am There are some bad reviews there. It appears to be a cheap copy with a dodgy power supply. We don't buy cheap junk. It's just not worth it. Better of spending a little more for a better quality one.
suoertrogg
Just a quick post to say thank you to asmcom for the prompt handling of my recent order for a BU40N and case.
Delivery was very fast, communication excellent.
