Tropic Thunder Issues
rhpot1991
#1 Post by rhpot1991 » Wed Oct 20, 2010 10:41 pm
I have seen issues with multiple copies of Tropic Thunder:
MakeMKV v1.6.1 linux(x64-release) started
Debug logging enabled, log will be saved as /home/john/MakeMKV_log.txt
File 00005.mpls was added as title #0
File 00003.mpls was added as title #1
Title #00003.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00005.m2ts was added as title #2
File 00006.m2ts was added as title #3
File 00007.m2ts was added as title #4
File 00008.m2ts was added as title #5
File 00009.m2ts was added as title #6
File 00010.m2ts was added as title #7
File 00011.m2ts was added as title #8
File 00012.m2ts was added as title #9
File 00013.m2ts was added as title #10
File 00014.m2ts was added as title #11
File 00015.m2ts was added as title #12
File 00016.m2ts was added as title #13
Title #00017.m2ts has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00021.m2ts was added as title #14
File 00022.m2ts was added as title #15
File 00023.m2ts was added as title #16
Title #00024.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #17
File 00027.m2ts was added as title #18
Saving 1 titles into directory /var/lib/mythtv/ultramagnus/videos/Blu-ray/Tropic_Thunder
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '1957490688'
DEBUG: Code 0 at sp?NC8ut=NV.%_^e:213137091
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '1973876736'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '1974988800'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '1975185408'
DEBUG: Code 101016576 at ?N=@lcfhPIi1P=hW@%:29395839
DEBUG: Code 101016576 at ?N=@lcfhPIi1P=hW@%:121261727
DEBUG: Code 0 at %)NTU/UZE(9sK/k#)hN:121263958
DEBUG: Code 0 at f$tVCZuLul'82OrwQWOY:29394298
DEBUG: Code 0 at WC~WR"J)+|f~S]$}h79<:121261681
DEBUG: Code 0 at f$tVCZuLul'82OrwQWOY:29394183
DEBUG: Code 964446 at f$tVCZuLul'82OrwQWOY:29393309
Failed to save title 0 to file /var/lib/mythtv/ultramagnus/videos/Blu-ray/Tropic_Thunder/title00.mkv
0 titles saved, 1 failed
setarip_old
Re: Tropic Thunder Issues
#2 Post by setarip_old » Thu Oct 21, 2010 12:35 am
Hi!
1) Are these all commercial, pressed Blu-ray discs?
2) Have you had success with any other Blu-ray discs?
rhpot1991
#3 Post by rhpot1991 » Thu Oct 21, 2010 12:39 am
Yes, they are all commercial pressed discs. I have had success with my other BR discs in the past. I have replaced the disc a few times in order to rule out physical damage, after seeing issues on 5 used discs I very much doubt this is the case.
setarip_old
#4 Post by setarip_old » Thu Oct 21, 2010 1:34 am
Netflix is my source
Sorry, but discussion regarding other-than-purchased media is not appropriate at the MakeMKV forums...
