tatts4Life
Re: Ultimate UHD Drives Guide Updated 2019
#136 Post by tatts4Life » Sun Jan 26, 2020 5:43 am
Same way my old drive was hooked up. I unhooked my original and plugged in the new drive using that same sata cables and power cables. I'm not using a usb adaptor like what was posted in the first post.
This happened also with the Asus drive the other day.
#137 Post by Billycar11 » Sun Jan 26, 2020 5:58 am
tatts4Life wrote: Sun Jan 26, 2020 5:43 am Same way my old drive was hooked up. I unhooked my original and plugged in the new drive using that same sata cables and power cables. I'm not using a usb adaptor like what was posted in the first post.
its quite strange multiple disks and drives being bad i have gotten 3-4 in a row bad before but i order many more then a normal person. i dont want to send you on a wild goose chase but you have a wild goose to chase.
tatts4Life
#138 Post by tatts4Life » Sun Jan 26, 2020 6:17 am
I've always been hesitant of buying from Amazon for this very reason. Thankfully my local Micro Center, the only store in my area that sells friendly drives, had the last WH16NS40 in stock. They have other Asus drives but who knows if exchanging them would be worth it. At this point I feel that if two different drives are giving the exact same problems exchanging for a new one would give the same result. I even cleaned the discs. I would buy new copies of the movies but feel I would get the same results with those too and couldn't get my money back. With the drives I could exchange for the same model or maybe get my money back.
tatts4Life
#139 Post by tatts4Life » Mon Jan 27, 2020 2:56 am
So I tried flashing other drives to my WH16NS40 and The Last Jedi loaded and started coping until 2 seconds left and failed. At this point I say I have bad copies of Endgame, TLJ, Guarians of the Galaxy vol.2, and Kingsmen. Hey at least it's only a small number out of the 30+ 4K movies I have.
senzaparole74
#140 Post by senzaparole74 » Thu Feb 06, 2020 9:16 am
Hi guys, can I buy the Asus BW-16D1H external burner?
Or do I have to buy the Asus BW-16D1H internal burner?
hart2hart
#141 Post by hart2hart » Thu Feb 06, 2020 4:51 pm
senzaparole74 wrote:Hi guys, can I buy the Asus BW-16D1H external burner?
...Or buy an internal and an enclosure.
senzaparole74
#142 Post by senzaparole74 » Thu Feb 06, 2020 7:08 pm
Thanks for the reply. I didn't understand what you mean, can you give an example?
#143 Post by Billycar11 » Thu Feb 06, 2020 9:15 pm
senzaparole74 wrote: Thu Feb 06, 2020 7:08 pm Thanks for the reply. I didn't understand what you mean, can you give an example?
Don't buy the external one for the 1000th time it's not the same model number
senzaparole74
#144 Post by senzaparole74 » Thu Feb 06, 2020 9:57 pm
I understand .. but I need an external burner. Can you recommend an external model?
#145 Post by Billycar11 » Thu Feb 06, 2020 9:59 pm
senzaparole74 wrote: Thu Feb 06, 2020 9:57 pm I understand .. but I need an external burner. Can you recommend an external model?
BU40N USB from me or buy one yourself
Jayden933
#146 Post by Jayden933 » Fri Feb 07, 2020 1:12 am
So to clarify, I have a brand new LG WH16NS40 with firmware version 1.04. The sticker on the drive says "SVC CODE: NS50" and manufactured September 2019.
Please confirm:
  1. I need to use the BH14NS40_N1.00-A4_patched.exe tool to flash the drive with the HL-DT-ST-BD-RE_BH16NS55-1.04-NM01701-211901041342.bin firmware.
  2. And then I need to use the same tool to flash it to the DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin firmware.
Is that all correct?
#147 Post by Billycar11 » Fri Feb 07, 2020 3:04 am
Jayden933 wrote: Fri Feb 07, 2020 1:12 am So to clarify, I have a brand new LG WH16NS40 with firmware version 1.04. The sticker on the drive says "SVC CODE: NS50" and manufactured September 2019.
Please confirm:
nah flash HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
and be done with it you fix not being able to downgrade you get faster ripping and no sleepbug
Jayden933
#148 Post by Jayden933 » Fri Feb 07, 2020 3:07 am
Billycar11 wrote: Fri Feb 07, 2020 3:04 am
Please confirm:
I thought if it had firmware version 1.04, you had to do a sidegrade first before you could do a downgrade?
#149 Post by Billycar11 » Fri Feb 07, 2020 8:00 pm
Jayden933 wrote: Fri Feb 07, 2020 3:07 am
1.02mk WH16NS60 is the equivalent of side grading and no need for downgrade if you use makemkv
Jayden933
#150 Post by Jayden933 » Fri Feb 07, 2020 11:42 pm
Billycar11 wrote: Fri Feb 07, 2020 8:00 pm
Ahh, I see now. I thought side-grading/cross-flashing just meant flashing an LG drive with an Asus firmware or an Asus drive with an LG firmware. I went ahead and just flashed my drive straight to HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin and it worked like a charm. I've already successfully been able to rip a few 4K UHD and regular blu-rays in MakeMKV with it. Thanks!
