does this disc just have a new dts hd with dtsx format mediainfo does not understand?
here is the mediainfo from the MKV rip:
General
Unique ID : 330902389361446976452201935579896835022 (0xF8F17B66955E2D9D8C33B39C3FD36BCE)
Complete name : /Volumes/Video/Movies/Zombieland Double Tap (2019)-2160p/Zombieland Double Tap (2019)_DTSHD-MA.UHD Blu-ray.HDR10.mkv
Format : Matroska
Format version : Version 2
File size : 41.1 GiB
Duration : 1h 39mn
Overall bit rate mode : Variable
Overall bit rate : 59.5 Mbps
Movie name : Zombieland: Double Tap
Encoded date : UTC 2020-01-11 17:39:03
Writing application : MakeMKV v1.14.7 linux(x64-release)
Writing library : libmakemkv v1.14.7 (1.3.5/1.4.7) x86_64-linux-gnu
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1h 39mn
Bit rate : 54.2 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.272
Stream size : 37.5 GiB (91%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1001 cd/m2
Maximum Frame-Average Light Level : 387 cd/m2
Original source medium : Blu-ray
Audio
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Duration : 1h 39mn
Bit rate mode : Variable
Bit rate : 5 292 Kbps
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Sampling rate : 48.0 KHz
Frame rate : 93.750 fps (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 3.66 GiB (9%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Text
ID in the original source medium : 4769 (0x12A1)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 28mn 6s
Bit rate : 487 bps
Count of elements : 14
Stream size : 100 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:05:01.134 : en:Chapter 02
00:11:08.000 : en:Chapter 03
00:15:24.173 : en:Chapter 04
00:21:16.191 : en:Chapter 05
00:29:15.545 : en:Chapter 06
00:36:55.421 : en:Chapter 07
00:44:03.015 : en:Chapter 08
00:50:12.968 : en:Chapter 09
00:57:52.510 : en:Chapter 10
01:03:51.869 : en:Chapter 11
01:06:50.047 : en:Chapter 12
01:10:12.124 : en:Chapter 13
01:15:40.494 : en:Chapter 14
01:23:45.311 : en:Chapter 15
01:29:48.216 : en:Chapter 16Code: Select all
General
Complete name : /Volumes/BT_Downloads/ZOMBIELAND_DOUBLE_TAP/BDMV/STREAM/00001.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 52.8 GiB
Duration : 1h 39mn
Overall bit rate : 76.4 Mbps
Maximum Overall bit rate : 109 Mbps
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Duration : 1h 39mn
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : DTS XLL
Muxing mode : Stream extension
Codec ID : 134
Duration : 1h 39mn
Bit depth : 24 bits
Audio #2
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 129
Duration : 1h 39mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Frame rate : 31.250 fps (1536 SPF)
Compression mode : Lossy
Delay relative to video : -8ms
Stream size : 453 MiB (1%)
Service kind : Complete Main
Audio #3
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #4
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #5
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #6
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #7
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #8
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #9
Menu ID : 1 (0x1)
Format : DTS XLL
Codec ID : 134
Duration : 1h 39mn
Channel layout : C L R Ls Rs LFE
Bit depth : 16 bits
Audio #10
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 448 Kbps
Stream size : 317 MiB (1%)
Audio #11
Menu ID : 1 (0x1)
Format : DTS XLL
Codec ID : 134
Duration : 1h 39mn
Bit depth : 16 bits
Audio #12
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #13
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 640 Kbps
Audio #14
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 1h 39mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Stream size : 136 MiB (0%)
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #3
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #4
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #5
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #6
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #7
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #8
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #9
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #10
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #11
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #12
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #13
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #14
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #15
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #16
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #17
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #18
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #19
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #20
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #21
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #22
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #23
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #24
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #25
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 7s 340ms
Text #26
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 7s 424ms
Text #27
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #28
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #29
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #30
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #31
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
