Jay and silent bob reboot correct playlist
omk1980
Post by omk1980 »
Anybody have the right playlist for this DVD? only seeing threads for the bluray copy.
Volkmeer
Re: Jay and silent bob reboot correct playlist
Post by Volkmeer »
Any luck with this one?
omk1980
Post by omk1980 »
No, how about you?
ffgoas
Post by ffgoas »
Title 60 worked for me. Had to select manually.
omk1980
Post by omk1980 »
Awesome. Thanks!
omk1980
Post by omk1980 »
not seeing 60. I've got 57, 58, 59, 61, 63. I'll try 58. What was the exact length of playlist 60? thanks for your help
ffgoas
Post by ffgoas »
You have to open the dvd manually. You can then select 60 and list the chapters.
ffgoas
Post by ffgoas »
if you select 57, 58 ,59 and then 61 you can see what files it is opening. Did the same for me. As MKV is opening the disc you will see 60 has some error. That is why it does not show up in the menu.
ffgoas
Post by ffgoas »
It was "open dvd file manually" or "open disc" in the files menu.
omk1980
Post by omk1980 »
Gotcha. that's wild. never done that before. backing up now. thanks again
