The Lion King UHD 4K doesn't have video
The disc opened just fine with MakeMKV 1.14.7 on my LG WH16NS40 with 1.02 bios. I was able to start the rip, and it completed without errors, but the file video freezes a half second into the Disney intro, and then produces a checkered picture that stays on the screen while the audio plays on. The audio continues just fine, just the video seems not to have ripped properly.
Re: The Lion King UHD 4K doesn't have video
We’re going to need more information other than “it just doesn’t play”. Gotta help us help you a little better.
Are you ripping to an MKV container or using the full folder structure backup?
Are you playing it on a standalone UHD player (e.g OPPO, Pioneer, other)? If so, which one?
Are you playing it on a HTPC? If so, what software player are you using where this is happening (e.g VLC, MPC-BE + MadVR, PowerDVD, etc)?
If on an HTPC, have you tried other players outside of the current one you’re using? If so, same exact behavior?
If on an HTPC, have you confirmed that your video card can play/support 4K/UHD playback/codecs? Have you played in full other UHD BD rips successfully using that exact same setup?
