Failed to get full access to drive
spiritofone420
Post by spiritofone420 »
I am trying to run makeMKV on my Umbuntu 18.04.3 machine to convert an .avi file. The software is returning this error:
Failed to get full access to drive "TSSTcorp DVD+-RW TS-L632H". Make sure that you either have write access to device "/dev/sr0", are member of "cdrom" group or have CAP_SYS_RAWIO enabled.
So after running the following commands these are the responses I receive:
~$ ls -l /dev/sr0
brw-rw----+ 1 root cdrom 11, 0 Feb 1 11:09 /dev/sr0
$ getfacl /dev/sr0
getfacl: Removing leading '/' from absolute path names
# file: dev/sr0
# owner: root
# group: cdrom
user::rw-
user:gary:rw-
group::rw-
mask::rw-
other::---
~$ whoami
gary
So being new to the world of Linux would someone tell me what else I need to do and exactly HOW ... preferably in NON GEEK ... thank you!
Re: Failed to get full access to drive
Not sure what AVI files have to do with this - MakeMKV does not create AVI files, and I don't think it reads them.
There is also another topic with the same subject in this forum: viewtopic.php?f=3&t=21393
spiritofone420
Woodstock wrote:
Sun Feb 02, 2020 12:44 am
I was thinking of that myself, but the error made no mention of the file type. I will try with a store bought DVD and see if the same happens. Sorry about not seeing the other post, not like it buried either. Thx.
If you're talking about an AVI file on a DVD data disk, you don't need MakeMKV to read that; you should be able to copy it directly. MakeMKV would fail if the disk isn't formatted as video DVD disk, because things it needs would not be there.
ornithopterjumpsuit
Post by ornithopterjumpsuit »
I have the same issue with a different model drive ("Failed to get full access to drive "HL-DT-ST BD-RE BU40N". Make sure that you either have write access to device "/dev/sr0", are member of "cdrom" group or have CAP_SYS_RAWIO enabled.").
Note that 'groups' returns cdrom.
Could this be a BIOS problem? Note that the same hardware booting in Win10 runs makemkv fine.
Any help for a Ubuntu 18.04 Linux n00b is greatly appreciated.
Thanks.
ornithopterjumpsuit
I forgot to mention this is an slimline SATA drive connected internally.
Anybody have any ideas?
ornithopterjumpsuit
I figured it out in my case: I'd used a snap install via:
https://connectwww.com/how-to-install-m ... ter/61127/
After uninstalling, and reinstalling via unofficial PPA above, all is now well(-ish).
