Brooks6969
Post by Brooks6969 » Sun Jan 26, 2020 6:58 pm
Thanks for the heads up NoeGo. I just signed up for an account to thank you because I was running into the same issue. Had to install 3.1 first, even though the drive already had 3.1, then install 3.02.
The 3.1 is buried in the file system there though so it took me a while to find it.
jeremybrice
Post by jeremybrice » Sat Feb 01, 2020 9:26 pm
MartyMcNuts wrote: Mon Dec 30, 2019 11:39 pm
tribble wrote: Mon Dec 30, 2019 1:34 pm
MartyMcNuts wrote: Tue Nov 26, 2019 11:51 pm
Please read the first post of this very thread. The BP50NB40 SVC: NB50 is supported. The SVC: NB40 is not guaranteed to be flashable but you can try it if you want to.
What's the worst that can happen, I brick my drive? Or is it just going to fail and give me an error number? Just want to be sure.
I have flashed a BP50NB40 (SVC: NB40) before for a customer. I warned him that the SVC: NB40 hadn't been flash tested before but he wanted me to have a go anyway. It worked just fine. The only thing I can say is to make sure that MakeMKV says "Drive platform: MT1959" before attempting to flash it.
The very worst that could happen is that you would brick the drive but as I said, it worked just fine when I did it.
Hello. I see that you said you were successful flashing a BP50NB40 (SVC: NB40) drive. That's what I have and I want to attempt it. It was manufactured in 2017 and has the Drive platform: MT1959. I saw on the first page of instructions it said that I "Must use Marty's asus tool to flash 8/24/19 or later only with HBD Firmware only"
I'm not sure what "flash 8/24/19 or later only with HBD" means. Could you provide some guidance?
hart2hart
Post by hart2hart » Sat Feb 01, 2020 10:39 pm
Just want to confirm.... Are ASUS BW-16D1HT that are being sold today still capable of being downgraded to 3.02? Do you have to locate and install a patched version of 3.1 (if that's what it has out of box) then downgrade to 3.02?
Post by MartyMcNuts » Sat Feb 01, 2020 11:13 pm
jeremybrice wrote: Sat Feb 01, 2020 9:26 pm
1. Use the latest version of the modified ASUS flasher (dated 24/8/2019).
2. To make it UHD friendly, please flash the HBD (hybrid firmware.)
Please read the first post in this very thread to get a better understanding.
Post by MartyMcNuts » Sat Feb 01, 2020 11:14 pm
hart2hart wrote: Sat Feb 01, 2020 10:39 pm Just want to confirm.... Are ASUS BW-16D1HT that are being sold today still capable of being downgraded to 3.02? Do you have to locate and install a patched version of 3.1 (if that's what it has out of box) then downgrade to 3.02?
Yes, they are. Just flash 3.10-MK first. Then you can flash 3.02. Both of these firmwares are included with the modified ASUS flasher in the first post of this thread.
jeremybrice
Post by jeremybrice » Sun Feb 02, 2020 12:22 am
MartyMcNuts wrote: Sat Feb 01, 2020 11:13 pm
I got it working! Thank you! And thank you for the kind response!
hart2hart
Post by hart2hart » Sun Feb 02, 2020 2:02 am
Thanks. Got a couple on order.
Maverick322
Post by Maverick322 » Thu Feb 06, 2020 6:09 pm
Sorry for the very simple question...newbie here. I think I understand the flashing part for a ASUS BW-16D1HT drive but my question is in regards to the connection of the drive to my laptop. Can I connect it via USB with a Vantec or OWC enclosure?
Post by Billycar11 » Thu Feb 06, 2020 9:17 pm
Maverick322 wrote: Thu Feb 06, 2020 6:09 pm Sorry for the very simple question...newbie here. I think I understand the flashing part for a ASUS BW-16D1HT drive but my question is in regards to the connection of the drive to my laptop. Can I connect it via USB with a Vantec or OWC enclosure?
I'm pretty sure your the same guy from YouTube but here https://www.makemkv.com/forum/viewtopic ... 16&t=19634
BurnerOfStuff
Post by BurnerOfStuff » Thu Feb 06, 2020 10:33 pm
I hope someone can help me. I've read thru the pages of info across the few threads and have gotten myself pretty confused. I've bought a LG WH16NS40 drive SVC50 with 1.04
I've installed the drive internally to my windows 10 pc with a sata cable.
My understanding is the 1.04 requires me to use the ASUS flasher to flash NS55 1.04 MK.
then i can flash to the proper firmware that will enable UHD and libredrive.
My questions would be, where do i find the asus flasher to install it, and where do i find the NS55 1.04 Mk file?
Once i've done that, what firmware file should i be installing?
This is my first time trying something like this and i'd hate to brick my new drive.
jkf76
Post by jkf76 » Fri Feb 07, 2020 12:06 am
jeremybrice wrote: Sun Feb 02, 2020 12:22 am
Greetings,
I'm getting error #5 when I try this with my drive.
I've got the same drive as above, BP50NB40 (SVC NB40), firmware 1.00, manufacture date of Dec 2015. Drive platform shows as MT1959. When I try the process above, using the 8/24/19 Asus flasher, along with the DE_LG_BP60NB10_1.00_MK_HBD firmware, the drive tray immediately pops open, and a second later, error #5 pops up. I've searched through the boards for what error #5 is, but there seems to be very little info. If anyone knows what error #5 means, I'd love to hear it. I've seen the warning that SVC NB40 isn't guaranteed to be flashable, but I'd like to understand the difference between the NB40/NB50 SVC codes and if my issue can be corrected. I'm encouraged a couple people have managed to make it work.
For reference, this is on a Win 10 (1903) PC.
Post by Billycar11 » Fri Feb 07, 2020 12:48 am
BurnerOfStuff wrote: Thu Feb 06, 2020 10:33 pm Hello,
all the relevant links to the flasher are here and most firmware too i think but i recommend you just flash that drive to WH16NS60 1.02mk and that can be found here: https://www.makemkv.com/forum/viewtopic ... 19&t=19113
it will be one step that way and you will increase your rip speed and fix the sleepbug
Maverick322
Post by Maverick322 » Fri Feb 07, 2020 1:01 am
Billycar11 wrote: Thu Feb 06, 2020 9:17 pm
Thanks. Much appreciated.
Post by MartyMcNuts » Fri Feb 07, 2020 2:23 am
As Billy said, however, to make it easy for you, the flasher and firmware can be found in the first post of this very thread!!
Post by SamuriHL » Fri Feb 07, 2020 3:49 am
Come on Marty, you've not written a front end for makemkv flashing yet? Just teasing as we know Mike is working on one but wouldn't that be fun? Lol
