Brooks6969
Thanks for the heads up NoeGo. I just signed up for an account to thank you because I was running into the same issue. Had to install 3.1 first, even though the drive already had 3.1, then install 3.02.
The 3.1 is buried in the file system there though so it took me a while to find it.
jeremybrice
Hello. I see that you said you were successful flashing a BP50NB40 (SVC: NB40) drive. That's what I have and I want to attempt it. It was manufactured in 2017 and has the Drive platform: MT1959. I saw on the first page of instructions it said that I "Must use Marty's asus tool to flash 8/24/19 or later only with HBD Firmware only"MartyMcNuts wrote: Mon Dec 30, 2019 11:39 pmI have flashed a BP50NB40 (SVC: NB40) before for a customer. I warned him that the SVC: NB40 hadn't been flash tested before but he wanted me to have a go anyway. It worked just fine. The only thing I can say is to make sure that MakeMKV says "Drive platform: MT1959" before attempting to flash it.tribble wrote: Mon Dec 30, 2019 1:34 pmWhat's the worst that can happen, I brick my drive? Or is it just going to fail and give me an error number? Just want to be sure.MartyMcNuts wrote: Tue Nov 26, 2019 11:51 pm
Please read the first post of this very thread. The BP50NB40 SVC: NB50 is supported. The SVC: NB40 is not guaranteed to be flashable but you can try it if you want to.
The very worst that could happen is that you would brick the drive but as I said, it worked just fine when I did it.
I'm not sure what "flash 8/24/19 or later only with HBD" means. Could you provide some guidance?
Just want to confirm.... Are ASUS BW-16D1HT that are being sold today still capable of being downgraded to 3.02? Do you have to locate and install a patched version of 3.1 (if that's what it has out of box) then downgrade to 3.02?
1. Use the latest version of the modified ASUS flasher (dated 24/8/2019).jeremybrice wrote: Sat Feb 01, 2020 9:26 pmHello. I see that you said you were successful flashing a BP50NB40 (SVC: NB40) drive. That's what I have and I want to attempt it. It was manufactured in 2017 and has the Drive platform: MT1959. I saw on the first page of instructions it said that I "Must use Marty's asus tool to flash 8/24/19 or later only with HBD Firmware only"MartyMcNuts wrote: Mon Dec 30, 2019 11:39 pmI have flashed a BP50NB40 (SVC: NB40) before for a customer. I warned him that the SVC: NB40 hadn't been flash tested before but he wanted me to have a go anyway. It worked just fine. The only thing I can say is to make sure that MakeMKV says "Drive platform: MT1959" before attempting to flash it.tribble wrote: Mon Dec 30, 2019 1:34 pm
2. To make it UHD friendly, please flash the HBD (hybrid firmware.)
Please read the first post in this very thread to get a better understanding.
Yes, they are. Just flash 3.10-MK first. Then you can flash 3.02. Both of these firmwares are included with the modified ASUS flasher in the first post of this thread.hart2hart wrote: Sat Feb 01, 2020 10:39 pm Just want to confirm.... Are ASUS BW-16D1HT that are being sold today still capable of being downgraded to 3.02? Do you have to locate and install a patched version of 3.1 (if that's what it has out of box) then downgrade to 3.02?
jeremybrice
I got it working! Thank you! And thank you for the kind response!MartyMcNuts wrote: Sat Feb 01, 2020 11:13 pm1. Use the latest version of the modified ASUS flasher (dated 24/8/2019).jeremybrice wrote: Sat Feb 01, 2020 9:26 pmHello. I see that you said you were successful flashing a BP50NB40 (SVC: NB40) drive. That's what I have and I want to attempt it. It was manufactured in 2017 and has the Drive platform: MT1959. I saw on the first page of instructions it said that I "Must use Marty's asus tool to flash 8/24/19 or later only with HBD Firmware only"MartyMcNuts wrote: Mon Dec 30, 2019 11:39 pm
Thanks. Got a couple on order.MartyMcNuts wrote:Yes, they are. Just flash 3.10-MK first. Then you can flash 3.02. Both of these firmwares are included with the modified ASUS flasher in the first post of this thread.hart2hart wrote: Sat Feb 01, 2020 10:39 pm Just want to confirm.... Are ASUS BW-16D1HT that are being sold today still capable of being downgraded to 3.02? Do you have to locate and install a patched version of 3.1 (if that's what it has out of box) then downgrade to 3.02?
Maverick322
Sorry for the very simple question...newbie here. I think I understand the flashing part for a ASUS BW-16D1HT drive but my question is in regards to the connection of the drive to my laptop. Can I connect it via USB with a Vantec or OWC enclosure?
I'm pretty sure your the same guy from YouTube but here https://www.makemkv.com/forum/viewtopic ... 16&t=19634Maverick322 wrote: Thu Feb 06, 2020 6:09 pm Sorry for the very simple question...newbie here. I think I understand the flashing part for a ASUS BW-16D1HT drive but my question is in regards to the connection of the drive to my laptop. Can I connect it via USB with a Vantec or OWC enclosure?
BurnerOfStuff
I hope someone can help me. I've read thru the pages of info across the few threads and have gotten myself pretty confused. I've bought a LG WH16NS40 drive SVC50 with 1.04
I've installed the drive internally to my windows 10 pc with a sata cable.
My understanding is the 1.04 requires me to use the ASUS flasher to flash NS55 1.04 MK.
then i can flash to the proper firmware that will enable UHD and libredrive.
My questions would be, where do i find the asus flasher to install it, and where do i find the NS55 1.04 Mk file?
Once i've done that, what firmware file should i be installing?
This is my first time trying something like this and i'd hate to brick my new drive.
Greetings,jeremybrice wrote: Sun Feb 02, 2020 12:22 amI got it working! Thank you! And thank you for the kind response!MartyMcNuts wrote: Sat Feb 01, 2020 11:13 pm1. Use the latest version of the modified ASUS flasher (dated 24/8/2019).jeremybrice wrote: Sat Feb 01, 2020 9:26 pm
I'm getting error #5 when I try this with my drive.
I've got the same drive as above, BP50NB40 (SVC NB40), firmware 1.00, manufacture date of Dec 2015. Drive platform shows as MT1959. When I try the process above, using the 8/24/19 Asus flasher, along with the DE_LG_BP60NB10_1.00_MK_HBD firmware, the drive tray immediately pops open, and a second later, error #5 pops up. I've searched through the boards for what error #5 is, but there seems to be very little info. If anyone knows what error #5 means, I'd love to hear it. I've seen the warning that SVC NB40 isn't guaranteed to be flashable, but I'd like to understand the difference between the NB40/NB50 SVC codes and if my issue can be corrected. I'm encouraged a couple people have managed to make it work.
For reference, this is on a Win 10 (1903) PC.
all the relevant links to the flasher are here and most firmware too i think but i recommend you just flash that drive to WH16NS60 1.02mk and that can be found here: https://www.makemkv.com/forum/viewtopic ... 19&t=19113BurnerOfStuff wrote: Thu Feb 06, 2020 10:33 pm Hello,
it will be one step that way and you will increase your rip speed and fix the sleepbug
Maverick322
Thanks. Much appreciated.Billycar11 wrote: Thu Feb 06, 2020 9:17 pmI'm pretty sure your the same guy from YouTube but here https://www.makemkv.com/forum/viewtopic ... 16&t=19634Maverick322 wrote: Thu Feb 06, 2020 6:09 pm Sorry for the very simple question...newbie here. I think I understand the flashing part for a ASUS BW-16D1HT drive but my question is in regards to the connection of the drive to my laptop. Can I connect it via USB with a Vantec or OWC enclosure?
As Billy said, however, to make it easy for you, the flasher and firmware can be found in the first post of this very thread!!BurnerOfStuff wrote: Thu Feb 06, 2020 10:33 pm Hello,
Come on Marty, you've not written a front end for makemkv flashing yet?
Just teasing as we know Mike is working on one but wouldn't that be fun? Lol
Just teasing as we know Mike is working on one but wouldn't that be fun? LolSent from my SM-G975U using Tapatalk
