Makemkv not working on new discs
met_fan
I just tried four new discs...Joker, Maleficent Mistress of Evil, Ad Astra, and Hustlers. They all failed and gave me the message "failed to open disc." Older discs still work fine - I just got Mission Impossible Ghost Protocol and it worked fine. What might be going on that new discs are all failing for me?
Re: Makemkv not working on new discs
Debug log? What you've posted so far could be "disk scratched and cracked" or "too new to have a key yet so I need to send the file that was generated by the attempt to svq@makemkv.com so that a key can be added."
met_fan
It's definitely telling me the volume keys are missing. I submitted a dump for Joker a week ago. Here is the dubug log:
Debug log started at Sat Feb 1 13:27:05 2020 , written by MakeMKV v1.14.7 darwin(x64-release)
001005:0000 MakeMKV v1.14.7 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Matthew/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE ASUS BW-16D1HT 3.00d" opened in OS access mode.
003338:0000 Downloading latest SDF to /Users/Matthew/Library/MakeMKV ...
003339:0000 Automatic SDF downloading is disabled or failed.
001003:0020 DEBUG: Code 106 at u'%=,LK6\QSA4~*%:213143922
SDF v063: ASUS_BW-16D1HT_3.00_211511031110_SIK9CH1LF231
001011:0000 Using LibreDrive mode (v05 id=F0ED16432FAA)
DEBUG: Code 2147483648 at u'%=,LK6\QSA4~*%:213132974
003338:0000 Downloading latest HK to /Users/Matthew/Library/MakeMKV ...
001003:0020 DEBUG: Code 0 at u'%=,LK6\QSA4~*%:121267500
003339:0000 Automatic HK downloading is disabled or failed.
003332:0000 Saved AACS dump file as /Users/Matthew/Library/MakeMKV/MKB20_v72_Joker_362C.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at }^B2:w]`vojNZxRo:29396092
001003:0020 DEBUG: Code 0 at }^B2:w]`vojNZxRo:29395172
Application exited at Sat Feb 1 13:30:05 2020
Grauhaar
MakeMKV can not load/update keys from the servermet_fan wrote: Sat Feb 01, 2020 1:41 pm 003338:0000 Downloading latest SDF to /Users/Matthew/Library/MakeMKV ...
Good Luck
met_fan
It’s not disabled in the preferences
Grauhaar
No connection to the internet, or the DNS server could not resolve the name to an IP, or or or ...
Good Luck
met_fan
Disconnected my Mac from the internet and connected it to my phone's hotspot and it finally worked again.
