Dexter Season 2 Disc 1
Darkhunter2121
Post by Darkhunter2121 »
I need some help I just purchased the Dexter Complete series box set i got it from a guy on let go and i checked all discs before purchase. I was able to rip all the discs up to season 4 without a problem except season 2 disc 1 where it will do 2 out of 4 of the episodes. Here is the log if anyone can help me understand whats wrong will be a great help.
MakeMKV v1.14.7 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/RMAC/MakeMKV_log.txt
Optical drive "BD-RE ASUS BW-16D1X-U E111d" opened in OS access mode.
Title #00100.mpls has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.mpls was added as title #0
File 00004.mpls was added as title #1
File 00001.mpls was added as title #2
File 00003.mpls was added as title #3
File 00002.mpls was added as title #4
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 4 titles into directory /Users/RMAC/Movies/Dexter Season 2
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '4003725312'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '4009949184'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '4009949184'
DEBUG: Code 1073741829 at ^#eX_+A%Tn8&;8al>[:29394758
DEBUG: Code 100864261 at ^#eX_+A%Tn8&;8al>[:29394758
DEBUG: Code 0 at B+mIsYmnIAn;);L:\dP::29395011
DEBUG: Code 0 at MK'1K\X2-eE@dY'w{!S<:29394068
DEBUG: Code 0 at B+mIsYmnIAn;);L:\dP::29394459
DEBUG: Code 1957983 at B+mIsYmnIAn;);L:\dP::29393286
DEBUG: Code 0 at 4gR9l=vu8d2skdQEfM3}-:213136608
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /Users/RMAC/Movies/Dexter Season 2/Dexter Season 2_t00.mkv
AV synchronization issues were found in file 'Dexter Season 2_t02.mkv' (title #3)
Forced subtitles track #6 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'Dexter Season 2_t03.mkv' (title #4)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '8158642176'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '8158642176'
DEBUG: Code 3983712 at B+mIsYmnIAn;);L:\dP::29393286
Failed to save title 4 to file /Users/RMAC/Movies/Dexter Season 2/Dexter Season 2_t04.mkv
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
2 titles saved, 2 failed
hart2hart
Re: Dexter Season 2 Disc 1
Post by hart2hart »
That’s saying it can’t read the disc. Clean it even if it already look okay. Also, sometime another drive can read them.
