Drive stopped reading Blu-Rays
nhigham
#1 Post by nhigham » Wed Jan 29, 2020 1:53 pm
I've used MakeMKV for quite a while and managed to rip virtually all of my disks. Recently it stopped reading Blu-Rays and now I've just checked other Blu-Rays that had previously copied and it can't read those either. I think the first ones I noticed it on were Harry Potter ones, but now it won't read anything. I've found a thread mentioning AACS as being a possible cause and that if a later version of AACS is detected on a disk then it revokes permission for MakeMKV to read any Blu-Ray after that, but I didn't find any solution? It mentioned checking in the data directory for and files beginning "MVB-v" but I can't find any.
Is there any way of fixing this or is the drive now bricked for Blu-Rays?
Thanks,
Neil
Re: Drive stopped reading Blu-Rays
#2 Post by Woodstock » Wed Jan 29, 2020 5:50 pm
It depends. What version of MakeMKV are you running? What version of AACS did you load that revoked the disk key?
In your MakeMKV data directory, look for files that start with MKB and end with tgz. What's the highest number shown after the MKB?
Note that it is VERY unusual for there not to be MKB files in the data directory, unless MakeMKV doesn't have permission to write there.
Grauhaar
#3 Post by Grauhaar » Wed Jan 29, 2020 6:19 pm
The best is always, provide a debug log which shows infos and errors.
Good Luck :)
nhigham
#4 Post by nhigham » Thu Jan 30, 2020 9:40 am
Hi both,
The only file in my MakeMKV folder is _private_data.tar. I've tried changing the location of the Data Directory and restarted MakeMKV but it still just creates the same file. The log messages in the bottom window are below, but it doesn't create the log.txt file either?
MakeMKV v1.14.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Neil/MakeMKV_log.txt
Downloading latest SDF to D:/Neil/MakeMKV ...
nhigham
#5 Post by nhigham » Thu Jan 30, 2020 9:46 am
Sorry I've just realised that the log file is not written to the Data Directory! Log file contents below:
Debug log started at Thu Jan 30 09:43:30 2020 , written by MakeMKV v1.14.7 win(x64-release)
001005:0000 MakeMKV v1.14.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Neil/MakeMKV_log.txt
No SDF v06a: HL-DT-ST_DVDRAM_GH24NSD0_LH00_201506111124_K25G1SA4649
SDF id v06a: HL-DT-ST_DVDRAM_GH24NSD0_LH00_201506111124_K25G1SA4649
Application exited at Thu Jan 30 09:44:50 2020
#6 Post by Woodstock » Thu Jan 30, 2020 1:17 pm
Can I see a log where you inserted a BD, and attempted to read it, please?
Cave Man
#7 Post by Cave Man » Thu Jan 30, 2020 2:14 pm
This happened to me a few weeks ago. The solution was to shut my computer down, unplug the AC for 10 seconds, then restart. A restart alone was not enough. I suspect my Asus drive had an issue that required a complete power-off. May not work for you, but if you haven't tried it it's worth a shot.
nhigham
#8 Post by nhigham » Thu Jan 30, 2020 2:25 pm
Woodstock wrote: Thu Jan 30, 2020 1:17 pm Can I see a log where you inserted a BD, and attempted to read it, please?
The one above is when trying to read a Blu-Ray. I've just tried it again and it says the same. The drive chugs for about a minute saying "Disc is being loaded" and then goes to "No disc inserted"
Grauhaar
#9 Post by Grauhaar » Thu Jan 30, 2020 3:02 pm
The detection of the disc is done by the Operating System and not by MakeMKV. As long has Windows does not detected the disc, MakeMKV cannot see and access the disc.
Good Luck :)
nhigham
#10 Post by nhigham » Wed Feb 05, 2020 6:27 pm
Looks like the drive must have gone faulty. I've just swapped for an old Blu-Ray drive and it's working again. Thanks for your help.
