Blade Runner 4K will not open.
philb1701
Post by philb1701 »
When attempting to open the 4K UHD Blade Runner disc, I get this error message:
MakeMKV v1.14.7 darwin(x64-release) started
Profile parsing error: default profile missing, using builtin default
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS31N TA17d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.00d" opened in OS access mode.
Using LibreDrive mode (v05 id=64754CF46FCA)
Saved AACS dump file as /Users/pbarker/Library/MakeMKV/MKB20_v61_Blade_Runner-_The_Final_Cut_18AD.tgz
Failed to open disc.
(88.44 KiB) Downloaded 502 times
st4evr
Re: Blade Runner 4K will not open.
Post by st4evr »
Read this post and submit the file as discussed there:
https://www.makemkv.com/forum/viewtopic ... 389#p83389
Same applies to you. Posting the file in the forum is of no help as no one here can do anything with that file. Only the developer can.
Forum search function works. Use it. It will often quickly provide answers to these common errors and/or questions as well.
https://www.makemkv.com/forum/search.ph ... +this+disc+
Additionally, make sure you are connected to the internet and in the app settings you've allowed it to connect to MakeMKV server(s) as also discussed in the first linked post.
philb1701
Post by philb1701 »
Done and done.
Thanks for the heads up.
wrooty
Post by wrooty »
Have you been able to rip your disk yet? I've been having issues with my copy too, submitted my error file on jan 15th and it still won't rip.
philb1701
Post by philb1701 »
Still can't rip mine. I've tried two different discs, same results.
Submitted the support tickets with requested support materials, no response yet.
