Zombieland Double Tap DTSX Issue
spl147
Post by spl147 »
disc rips fine, but dtsx is lost in the process, the disc has dtsx, but when i convert to mkv there is no dtsx, when i rip to folder backup there is no dtsx.
does this disc just have a new dts hd with dtsx format mediainfo does not understand?
here is the mediainfo from the MKV rip:
General
Unique ID                                : 330902389361446976452201935579896835022 (0xF8F17B66955E2D9D8C33B39C3FD36BCE)
Complete name                            : /Volumes/Video/Movies/Zombieland Double Tap (2019)-2160p/Zombieland Double Tap (2019)_DTSHD-MA.UHD Blu-ray.HDR10.mkv
Format version                           : Version 2
File size                                : 41.1 GiB
Duration                                 : 1h 39mn
Overall bit rate                         : 59.5 Mbps
Movie name                               : Zombieland: Double Tap
Encoded date                             : UTC 2020-01-11 17:39:03
Writing application                      : MakeMKV v1.14.7 linux(x64-release)
Writing library                          : libmakemkv v1.14.7 (1.3.5/1.4.7) x86_64-linux-gnu
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1h 39mn
Bit rate                                 : 54.2 Mbps
Frame rate                               : 23.976 (24000/1001) fps
Bits/(Pixel*Frame)                       : 0.272
Stream size                              : 37.5 GiB (91%)
Maximum Content Light Level              : 1001 cd/m2
Maximum Frame-Average Light Level        : 387 cd/m2
Audio
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Duration                                 : 1h 39mn
Bit rate                                 : 5 292 Kbps
Channel layout                           : C L R LFE Lb Rb Lss Rss
Sampling rate                            : 48.0 KHz
Frame rate                               : 93.750 fps (512 SPF)
Stream size                              : 3.66 GiB (9%)
Text
ID in the original source medium         : 4769 (0x12A1)
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 28mn 6s
Bit rate                                 : 487 bps
Count of elements                        : 14
Stream size                              : 100 KiB (0%)
Menu
00:00:00.000                             : en:Chapter 01
00:05:01.134                             : en:Chapter 02
00:11:08.000                             : en:Chapter 03
00:15:24.173                             : en:Chapter 04
00:21:16.191                             : en:Chapter 05
00:29:15.545                             : en:Chapter 06
00:36:55.421                             : en:Chapter 07
00:44:03.015                             : en:Chapter 08
00:50:12.968                             : en:Chapter 09
00:57:52.510                             : en:Chapter 10
01:03:51.869                             : en:Chapter 11
01:06:50.047                             : en:Chapter 12
01:10:12.124                             : en:Chapter 13
01:15:40.494                             : en:Chapter 14
01:23:45.311                             : en:Chapter 15
01:29:48.216                             : en:Chapter 16
Here is the Mediainfo from the FULL disc unprotected Backup:
General
Complete name                            : /Volumes/BT_Downloads/ZOMBIELAND_DOUBLE_TAP/BDMV/STREAM/00001.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 52.8 GiB
Duration                                 : 1h 39mn
Overall bit rate                         : 76.4 Mbps
Maximum Overall bit rate                 : 109 Mbps
Video
Duration                                 : 1h 39mn
Audio #1
Format                                   : DTS XLL
Muxing mode                              : Stream extension
Codec ID                                 : 134
Duration                                 : 1h 39mn
Audio #2
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Frame rate                               : 31.250 fps (1536 SPF)
Delay relative to video                  : -8ms
Stream size                              : 453 MiB (1%)
Audio #3
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #4
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #5
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #6
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #7
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #8
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #9
Format                                   : DTS XLL
Codec ID                                 : 134
Duration                                 : 1h 39mn
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Audio #10
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 448 Kbps
Stream size                              : 317 MiB (1%)
Audio #11
Format                                   : DTS XLL
Codec ID                                 : 134
Duration                                 : 1h 39mn
Bit depth                                : 16 bits
Audio #12
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #13
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 640 Kbps
Audio #14
Codec ID                                 : 129
Duration                                 : 1h 39mn
Bit rate                                 : 192 Kbps
Channel(s)                               : 2 channels
Channel layout                           : L R
Stream size                              : 136 MiB (0%)
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Text #3
Format                                   : PGS
Codec ID                                 : 144
Text #4
Format                                   : PGS
Codec ID                                 : 144
Text #5
Format                                   : PGS
Codec ID                                 : 144
Text #6
Format                                   : PGS
Codec ID                                 : 144
Text #7
Format                                   : PGS
Codec ID                                 : 144
Text #8
Format                                   : PGS
Codec ID                                 : 144
Text #9
Format                                   : PGS
Codec ID                                 : 144
Text #10
Format                                   : PGS
Codec ID                                 : 144
Text #11
Format                                   : PGS
Codec ID                                 : 144
Text #12
Format                                   : PGS
Codec ID                                 : 144
Text #13
Format                                   : PGS
Codec ID                                 : 144
Text #14
Format                                   : PGS
Codec ID                                 : 144
Text #15
Format                                   : PGS
Codec ID                                 : 144
Text #16
Format                                   : PGS
Codec ID                                 : 144
Text #17
Format                                   : PGS
Codec ID                                 : 144
Text #18
Format                                   : PGS
Codec ID                                 : 144
Text #19
Format                                   : PGS
Codec ID                                 : 144
Text #20
Format                                   : PGS
Codec ID                                 : 144
Text #21
Format                                   : PGS
Codec ID                                 : 144
Text #22
Format                                   : PGS
Codec ID                                 : 144
Text #23
Format                                   : PGS
Codec ID                                 : 144
Text #24
Format                                   : PGS
Codec ID                                 : 144
Text #25
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 7s 340ms
Text #26
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 7s 424ms
Text #27
Format                                   : PGS
Codec ID                                 : 144
Text #28
Format                                   : PGS
Codec ID                                 : 144
Text #29
Format                                   : PGS
Codec ID                                 : 144
Text #30
Format                                   : PGS
Codec ID                                 : 144
Text #31
Format                                   : PGS
Codec ID                                 : 144
apophis906
Re: Zombieland Double Tap DTSX Issue
Post by apophis906 »
I ripped my copy and it showed that it was just dts-ma as well. However when I played it my receiver showed dts-x. I Think it has to do with it being an imax enhanced one and some trick they did with the dts-x that mediainfo cant understand.
Esch30
Post by Esch30 »
I can also confirm that after ripping this disc, my receiver (Denon X8500H) displays IMAX DTS:X when bitstreaming via KODI on an ODROID N2, so everything appears to work as normal in regards to audio with this disc.
spl147
Post by spl147 »
Thank you both for clarifying
