Default output filename template using makemkvcon
rakorm
#1 Post by rakorm » Tue Jan 28, 2020 9:22 am
Is it possible to configure a default output filename for the commandline tool makemkvcon? I know, you can do that with the GUI-Version. How do I do that for makemkvcon?
Thanks and have a nice day :)
EDIT: Do I ask in the wrong forum?
Re: Default output filename template using makemkvcon
#2 Post by Woodstock » Fri Jan 31, 2020 3:22 pm
No, it's not a case of "the wrong forum", but more a case of not many people know the answer.
#3 Post by mike admin » Fri Jan 31, 2020 3:32 pm
This setting is stored in preferences. You can edit them in GUI and makemkvcon would pick them. Or you can edit preferences by hand, but this is only recommended as a last resort, if you have no gui at all.
rakorm
#4 Post by rakorm » Fri Jan 31, 2020 8:20 pm
Thanks for clearing this up. I have no gui, so I have to edit the preferences by hand. But: where do I find the preferences for the output filename template?
~/.MakeMKV has two files: settings.conf (written by me for app_Key) and update.conf (MakeMKV settings file, written by MakeMKV).
Are those files the 'preferences'?
#5 Post by mike admin » Fri Jan 31, 2020 11:38 pm
Which implies that your OS is Linux (settings are stored in different places on Windows, Mac and Linux).
The list of all settings can be (reliably) looked up in open-source part of MakeMKV - check the apdefs.h file. At the time of this writing the list is:
typedef enum _ApSettingId
  apset_dvd_MinimumTitleLength ,
  apset_dvd_TestMTL ,
  apset_dvd_SPRemoveMethod ,
  apset_app_DataDir ,
  apset_app_Key ,
  apset_app_KeyHash ,
  apset_io_ErrorRetryCount ,
  apset_io_IgnoreReadErrors ,
  apset_io_RBufSizeMB ,
  apset_io_TIPS_Server ,
  apset_app_ExpertMode ,
  apset_io_DarwinK2Workaround ,
  apset_fs_ForceIsoForUDF102 ,
  apset_app_DestinationType ,
  apset_app_DestinationDir ,
  apset_app_ShowDebug ,
  apset_app_PreferredLanguage ,
  apset_app_BackupDecrypted ,
  apset_app_InterfaceLanguage ,
  apset_app_UpdateEnable ,
  apset_io_SingleDrive ,
  apset_app_ShowAVSyncMessages ,
  apset_bdplus_DumpAlways ,
  apset_app_DefaultProfileName ,
  apset_app_DefaultSelectionString ,
  apset_app_Java ,
  apset_app_ccextractor ,
  apset_path_OpenFile ,
  apset_path_DestDir ,
  apset_app_DefaultOutputFileName ,
  apset_sdf_Stop ,
} ApSettingId;
The setting you are asked for is called app_DefaultOutputFileName, so you have to add the following to ~/settings.conf:
app_DefaultOutputFileName = "bla"
rakorm
#6 Post by rakorm » Sat Feb 01, 2020 8:33 am
Thank you mike, for answering in detail.
And: Thanks for MakeMKV!!!
