Default output filename template using makemkvcon
rakorm
Post by rakorm »
Is it possible to configure a default output filename for the commandline tool makemkvcon? I know, you can do that with the GUI-Version. How do I do that for makemkvcon?
Thanks and have a nice day :)
EDIT: Do I ask in the wrong forum?
Re: Default output filename template using makemkvcon
No, it's not a case of "the wrong forum", but more a case of not many people know the answer.
Post by mike admin »
This setting is stored in preferences. You can edit them in GUI and makemkvcon would pick them. Or you can edit preferences by hand, but this is only recommended as a last resort, if you have no gui at all.
rakorm
Post by rakorm »
mike admin wrote: Fri Jan 31, 2020 3:32 pm This setting is stored in preferences. You can edit them in GUI and makemkvcon would pick them. Or you can edit preferences by hand, but this is only recommended as a last resort, if you have no gui at all.
Thanks for clearing this up. I have no gui, so I have to edit the preferences by hand. But: where do I find the preferences for the output filename template?
~/.MakeMKV has two files: settings.conf (written by me for app_Key) and update.conf (MakeMKV settings file, written by MakeMKV).
Are those files the 'preferences'?
rakorm wrote: Fri Jan 31, 2020 8:20 pm ~/.MakeMKV has two files: settings.conf (written by me for app_Key) and update.conf (MakeMKV settings file, written by MakeMKV).
Which implies that your OS is Linux (settings are stored in different places on Windows, Mac and Linux).
The list of all settings can be (reliably) looked up in open-source part of MakeMKV - check the apdefs.h file. At the time of this writing the list is:
typedef enum _ApSettingId
  apset_dvd_MinimumTitleLength ,
  apset_dvd_TestMTL ,
  apset_dvd_SPRemoveMethod ,
  apset_app_DataDir ,
  apset_app_Key ,
  apset_app_KeyHash ,
  apset_io_ErrorRetryCount ,
  apset_io_IgnoreReadErrors ,
  apset_io_RBufSizeMB ,
  apset_io_TIPS_Server ,
  apset_app_ExpertMode ,
  apset_io_DarwinK2Workaround ,
  apset_fs_ForceIsoForUDF102 ,
  apset_app_DestinationType ,
  apset_app_DestinationDir ,
  apset_app_ShowDebug ,
  apset_app_PreferredLanguage ,
  apset_app_BackupDecrypted ,
  apset_app_InterfaceLanguage ,
  apset_app_UpdateEnable ,
  apset_io_SingleDrive ,
  apset_app_ShowAVSyncMessages ,
  apset_bdplus_DumpAlways ,
  apset_app_DefaultProfileName ,
  apset_app_DefaultSelectionString ,
  apset_app_Java ,
  apset_app_ccextractor ,
  apset_path_OpenFile ,
  apset_path_DestDir ,
  apset_app_DefaultOutputFileName ,
  apset_sdf_Stop ,
} ApSettingId;
The setting you are asked for is called app_DefaultOutputFileName, so you have to add the following to ~/settings.conf:
app_DefaultOutputFileName = "bla"
rakorm
Post by rakorm »
Thank you mike, for answering in detail.
And: Thanks for MakeMKV!!!
