Was about to import one of my newer blu-rays but ran into a crash-
Right after opening, after it gets right to the playlist selections it crashes.
It doesn't matter if I do it from directly on the disk or if I do it from a disk backup- both crash out.
Thoughts?
edit- crash screenshot attached
X-Men Dark Phoenix
X-Men Dark Phoenix
- makemkv1-14-7_2020-01-26.png (145.43 KiB) Viewed 5636 times
Re: X-Men Dark Phoenix
Performed scorched earth reinstall on the 1.14.7 makemkv install and was able to get this to work again- makes me curious why it persisted through a reboot as well though.
It was not limited to this Blu-ray, all the DVD's (manual or auto open) also failed in the same manner.
There are times when the hardware (drive, motherboard) gets out-of-sync, and rebooting doesn't fix things. A motherboard reset (or powering down the computer and restarting it) can do things that an operating system "reset" doesn't do.
