Help with failure...
Opentoe
Post by Opentoe »
I have a Caprica DVD and just trying to make an MKV file out of it. I'm using Slysoft's Virtual Clone Drive. I've mounted an ISO and MAKEMKV found it and parsed it. But when it tried to create the files it just kept failing. Can someone help me? Here is the log with the debug info: HELP!
MakeMKV v1.6.0 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\mdelig00/MakeMKV_log.txt
Title #0 has length of 203 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #1 has length of 185 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #2 has length of 215 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #3 has length of 187 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #4 has length of 788 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #5 has length of 429 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #6 has length of 429 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #7 has length of 14 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #8 has length of 24 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #9 has length of 306 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #10 has length of 34 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #11 has length of 60 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #12 has length of 33 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #13 has length of 39 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #14 has length of 78 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #15 has length of 75 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #16 has length of 164 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #17 has length of 66 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #18 has length of 17 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #19 has length of 83 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #20 has length of 152 seconds which is less than minimum title length of 2100 seconds and was therefore skipped
Title #21 was added (22 cell(s), 1:31:43)
Title #22 was added (20 cell(s), 1:28:16)
Title #23 was added (41 cell(s), 2:59:58)
Title #24 was added (22 cell(s), 1:31:43)
Title 4 in VTS 10 is equal to title 1 and was skipped
Saving 3 titles into directory E:/Video/CAPRICA_S1_0_D1
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213130490
DEBUG: Code 0 at T.g'OyG"}$?mfYyd3n=jW:213129639
DEBUG: Code 0 at ^m.0&P3(7X$IY\$JhQ@:29394183
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29394160
DEBUG: Code 0 at mbekjYvz,FE4*_>|AuF:29395195
Failed to save title 0 to file E:/Video/CAPRICA_S1_0_D1/title00.mkv
Failed to save title 1 to file E:/Video/CAPRICA_S1_0_D1/title01.mkv
Failed to save title 2 to file E:/Video/CAPRICA_S1_0_D1/title02.mkv
0 titles saved, 3 failed
setarip_old
Re: Help with failure...
Post by setarip_old »
Hi!
I have a Caprica DVD and just trying to make an MKV file out of it. I'm using Slysoft's Virtual Clone Drive. I've mounted an ISO...
1) There is NO purpose in first creating an .ISO image file.
2) However, if you want to use the .ISO image file, DO NOT mount it - MakeMKV prefers processing .ISO image files directly...
3) Try changing the "minimum title length" to its original default of 120 seconds and then use MakeMKV to rip the original, commercial DVD.
Opentoe
Post by Opentoe »
I have an ISO image from my Dad. He said he created it right from the DVD. I've tried using defaults, changing the time like you said, not mounting the ISO. Just about everything I can think of and just couldn't get any kind of MKV out of it. Not a real huge deal, as I can still watch the ISO with my media player. If the ISO was bad, I would suspect my media player wouldn't play it but it does.
setarip_old
How about one thing at a time? Did you try my suggestions with the "Caprica" DVD?
If so, how did things work out?
Post by mike admin »
A known problem in 1.6.0, please download 1.6.2
