IT Chapter 2 UHD (GER Version)
HelloThere
#1 Post by HelloThere » Thu Jan 23, 2020 7:16 pm
Hi there,
makemkv 1.14.7 doesn´t find the key for IT Chapter 2 (GER Version).
Dump file has been sent.
Thank you for the support...
Btw. is there a way to save an encoded version of this UHD disc, to generate an 1to1 copy later (when the key is in the database)?
Or to generate an .mkv from an encoded dump? Thank you....
Grauhaar
Re: IT Chapter 2 UHD (GER Version)
#2 Post by Grauhaar » Thu Jan 23, 2020 7:30 pm
Yes, use the "Backup" function.
Good Luck :)
HelloThere
#3 Post by HelloThere » Fri Jan 24, 2020 5:24 pm
Wow...that was fast !!
Thank you for the support....ripping right now :D
100% without any problems...thanks again
