Hi there,
makemkv 1.14.7 doesn´t find the key for IT Chapter 2 (GER Version).
Dump file has been sent.
Thank you for the support...
Btw. is there a way to save an encoded version of this UHD disc, to generate an 1to1 copy later (when the key is in the database)?
Or to generate an .mkv from an encoded dump? Thank you....
IT Chapter 2 UHD (GER Version)
Re: IT Chapter 2 UHD (GER Version)
Yes, use the "Backup" function.
Good Luck
Wow...that was fast !!
Thank you for the support....ripping right now
100% without any problems...thanks again
