2001 A Space Odyssey
tsartin
Re: 2001 A Space Odyssey
#16 Post by tsartin » Sat Feb 02, 2019 5:39 pm
Huge thanks to Mike and the devs. My copy of 2001 is now in the process of successfully backing up! :D
mfnotes
#17 Post by mfnotes » Sat Mar 09, 2019 4:56 am
Hi. Could anyone who's been able to get the UHD version to cooperate possibly send me a ping? I have a research question I'd love to ask. Thank you!
samue2000
#18 Post by samue2000 » Tue Jan 21, 2020 6:29 pm
@all
i have the same problem...
Can't rip this new UHD. Sent dump for my disc. Error was "volume key is unknown for this disc".
I use the v1.14.7 and the keys from 2019-12-09. Is my first UHD witch a "ripping problem!
@ Mike can you help me? I have send the dump file to :svq@makemkv.com
Sascha.
Using: ASUS BW-16D1HT 3.02 ext. over USB
Bluntman
#19 Post by Bluntman » Tue Jan 21, 2020 11:16 pm
I literally just got 2001 ASO 4K today from amazon.
Popped it into my drive and makemkv started ripping and decrypting just fine. Maybe I have a more common version?
It’s the red box cover with the booklet and box inside a large sleeve.
I wish I could offer you some insight however I’m sure mike is on it.
samue2000
#20 Post by samue2000 » Wed Jan 22, 2020 8:37 pm
@Bluntman
I have a German Standard Edition 3 Disc Pack.
4K UHD HDR10 witch Dolby Vision 2160p24.
BluRay Disc 1080p24
BluRay Disc "Specials" 1080p24
In the current key list are 11 keys for this 4K UHD Movie.
But not for my 4K UHD Disc Version....
Mtenga
#21 Post by Mtenga » Thu Oct 22, 2020 11:49 pm
Bought this from Amazon UK and still not working for me. Nor does The Invisible Man.
preserve
#22 Post by preserve » Thu Oct 22, 2020 11:54 pm
^ Relevant items from the stickied FAQ:
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Submit the dump file to svq@makemkv.com.
I see a movie discussed in the forum, but MakeMKV won't open my disc.
There are multiple versions of UHDs for each movie (countries, retailers, rentals) and there may be multiple keys for even the same version, so it's possible that your particular disc isn't decrypted yet. Submit the dump file!
Using: ASUS BW-16D1HT 3.00
