daddy
#1051 Post by daddy » Wed Jan 22, 2020 7:08 am
deadchip12 wrote:
Wed Jan 22, 2020 1:58 am
daddy wrote:
Tue Jan 21, 2020 6:55 pm
I did more than 60 Dolby Vision dual layer files.
Except Gemini Man (60fps=>stutter) and Universal Soldier (peak > 100 Mbps), all of them play fine on my C7.
What did you use to play them with? I try usb and some stutter (hdr10 always play fine but some dolby vision files do not). I want to try plex but the speed is limited by the internet.
mp4 files are on a DS416J nas.
The LG C7 Player access them in dlna.
deadchip12
#1052 Post by deadchip12 » Wed Jan 22, 2020 8:53 am
No buffering? I tried content sharing between my pc and oled c9 and it keeps buffering.
daddy
#1053 Post by daddy » Wed Jan 22, 2020 12:39 pm
no buffering at all, as long as the average bitrate of the file is below 85 Mbps.
max ethernet speed of the tv (network=Gigabit and fiber=1000/400 Mbps)
deadchip12
#1054 Post by deadchip12 » Wed Jan 22, 2020 3:00 pm
Mine is only 45. I guess this method is a no for me then.
superfans124
#1055 Post by superfans124 » Wed Jan 22, 2020 4:33 pm
you just need to upgrade your home network LAN to support gigabit ethernet between various ethernet ports on your devices, cat cables and the router.
daddy
#1056 Post by daddy » Wed Jan 22, 2020 6:19 pm
Unplugged the ethernet, turned off Quick Start (C7) and now in wifi 5Ghz i'm getting
deadchip12
#1057 Post by deadchip12 » Thu Jan 23, 2020 2:07 am
Ok so I did further testing with 3 movies: Hereditary, Paddington 2 and Gemini Man. They are played from my external hard drive connected to my c9 oled via usb.
-If I use Grencola tool, Hereditary & Paddington 2 in dolby vision suffer heavy stutterring. However, if I use the original method (ts muxer & mp4muxer), Hereditary & Paddington 2 in dolby vision play smoothly. Why is this the case?
-Regardless of what tool I use, Gemini Man in dolby vision always plays at lower than 60 fps. The hdr10 version however plays correctly at 60 fps. Any fix?
Grencola
#1058 Post by Grencola » Thu Jan 23, 2020 2:25 am
basically you're comparing eac3to.exe (used in my tool) and tsmuxer.exe.. eac3to will do the job 9 times out of 10 just fine. some releases have the odd frame error and eac3to can slip up.
deadchip12
#1059 Post by deadchip12 » Thu Jan 23, 2020 3:04 am
I see. I thought both are exactly the same.
Any idea to make gemini man dolby vision runs correctly at 60fps?
rosavanwinkle
#1060 Post by rosavanwinkle » Thu Jan 23, 2020 3:28 am
So can i in theory use dual layer dolby visions files on a fast usb drive then connect it too my shield tv pro(2019),and then what player should i use that is compatible with that?
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Grencola
#1061 Post by Grencola » Thu Jan 23, 2020 3:40 am
is all about the hardware. 4k 60fps @ 80mbps (~110 peak) is tough. you need fast components and even faster internet (if streaming). local media from an ssd or usb 3.0 drive on a tv w/ usb 3.0 would be ok so long as the tv model is adequate. even the shield pro with its crazy fast soc (tegra x1+) struggles on high bitrate 4k 60fps content.
Grencola
#1062 Post by Grencola » Thu Jan 23, 2020 3:45 am
when shield pro says it does dolby vision. it means it has the license and decoder for dvhe 5.06, a single layer profile meant for streaming. it won't play dual layer files. dvdfab can change around your dual layer files into single layer mp4s, but possibly at the risk of just getting hdr10 with a dolby flag on your tv.
deadchip12
#1063 Post by deadchip12 » Thu Jan 23, 2020 4:09 am
The hdr10 version runs fine at true 60 fps on my c9 via external hdd though. Only the dolby vision version runs at lower than 60fps (can tell by eyes). Is dolby vision more demanding hardware wise?
rosavanwinkle
#1064 Post by rosavanwinkle » Thu Jan 23, 2020 6:10 am
i'm gonna need a screenshot on how you convert too single layer,lets say i got this dual layer file atm (fantastic beasts crimes of grindlewald) its a MP4 ,how do i convert it?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Erfero
#1065 Post by Erfero » Thu Jan 23, 2020 7:45 pm
today i was reading the manual of the philips 804 i bought, and i found this:
What do you think it means? The assistance was unable to give me even half the information, they were able to say only "read the technical data sheet". I have not understood if he intends that the reader inside the TV is castrated at 30 \ 40 mpbs, or what else ...
The player inside the TV does not allow you to check the information of the video, so I don't know how much effective bandwidth it is from a Dolby Vision movie inserted from USB which theoretically should also have 80 mpbs ...
