Merlyn6175
#1036 Post by Merlyn6175 » Mon Jan 20, 2020 1:33 pm
"single layer mp4s from DVDFab, however, remain quite questionable at best.."
I think Grencola mean DVDfabs single layer conversion is questionable, which I agree.
Some conversion work flawless on my C7 and LG UHD BLuray(USB), however films like Transformers 1-4 just mess up, red & green flashes and if I use the UHD player it looks like i've dropped my screen with vertical coloured lines tearing up the screen.
Grencola
#1037 Post by Grencola » Mon Jan 20, 2020 8:16 pm
box4m wrote:
Mon Jan 20, 2020 5:32 am
Grencola wrote:
Mon Jan 20, 2020 4:01 am
Erfero wrote:
Sun Jan 19, 2020 8:26 pm
Hi guys, I've got Alida working with Dolby Vision through USB on a philips 804. Plex doesn't recognize dolby vision but only hdr 10 +.
I've simply used mp4muxer muxing BL + EL + audio. The process is slow, even with a nice PC, and even if says "0kb" in reality is working.
Anyway I don't see much difference from an HDR 10 +, is that normal? It looks like this process it's just a fake thing...
that's because, with current displays, hdr10+ is the equivalent to dolby vision. they both offer per-frame specular enhancement over regular hdr10. mp4muxer is definitely not fake as it keeps the seperate layers intact, just like uhd discs; it literally just changes the container. single layer mp4s from DVDFab, however, remain quite questionable at best..
questionable in what regard?
https://forum.mrmc.tv/viewtopic.php?f=1 ... &start=340
DaMacFunkin
#1038 Post by DaMacFunkin » Tue Jan 21, 2020 6:34 am
I have the same problem with bumblebee on the LG which is essentially a transformers film but it plays fine on the Shield Pto 2019.
deadchip12
#1039 Post by deadchip12 » Tue Jan 21, 2020 9:32 am
Hereditary dolby vision stutters on my lg c9, playing via hdd connected via usb. Other movies like Bumblebee and Fantastic Beasts play fine. Any idea?
DaMacFunkin
#1040 Post by DaMacFunkin » Tue Jan 21, 2020 12:36 pm
The USB ports on the C9 are only USB2.0, maybe the combination of your USB chipset and the v2 port isn’t quite fast enough for some high bit rate titles.
deadchip12
#1041 Post by deadchip12 » Tue Jan 21, 2020 1:13 pm
Usb 2.0 has a speed of 480 Mbps which is way higher than these films’ bitrate (less than 100 Mbps), so there shouldn’t be any problem right?
Btw, the hdr10 version of the same movie still runs fine, so I doubt this is a bit rate problem but the remuxed dolby version itself
DaMacFunkin
#1042 Post by DaMacFunkin » Tue Jan 21, 2020 4:20 pm
in theory yes, but in practice no, that’s why I mentioned the chipset.
Maybe your right, all I know is I have no probs with jitters or stutters with single layer DV playback on my C9, but I do have a shield serving it via wired LAN.
deadchip12
#1043 Post by deadchip12 » Tue Jan 21, 2020 5:22 pm
Is there a way to play these dolby vision fileS from pc?
daddy
#1044 Post by daddy » Tue Jan 21, 2020 6:55 pm
I did more than 60 Dolby Vision dual layer files.
Except Gemini Man (60fps=>stutter) and Universal Soldier (peak > 100 Mbps), all of them play fine on my C7.
deadchip12
#1045 Post by deadchip12 » Wed Jan 22, 2020 1:58 am
What did you use to play them with? I try usb and some stutter (hdr10 always play fine but some dolby vision files do not). I want to try plex but the speed is limited by the internet.
deadchip12
#1046 Post by deadchip12 » Wed Jan 22, 2020 4:16 am
Does anyone manage to play gemini man dolby vision smoothly at 60fps via usb? Mine seems to play at lower framerate. I used grencola tool.
box4m
#1047 Post by box4m » Wed Jan 22, 2020 5:07 am
Damn :(
scradion
#1048 Post by scradion » Wed Jan 22, 2020 5:13 am
It sounds like the LG 2017/2018/2019 OLED tvs do not seem to support HFR as Billy Lynn's Long Halftime Walk does not playback well over the LG tvs built in media player or through the Plex app. Billy Lynn's Long Halftime Walk(HFR 60fps) plays perfectly on the Nvidia Shield via gigabit Ethernet. It could also be the crappy wifi being too slow.
LG annoyingly got rid of the usb 3 port on the 2018 models and above. Since you have the LG C7 try an SSD(or a super fast USB 3 flash drive) hooked into the tv with a USB 3.0 to SSD adapter(I use the Sabrent EC-SSHD) and copy the the DL DV Gemini Man to that SSD and see if it plays on the internal media player. If it still lags like crazy the SoC is the culprit but if it plays perfectly then the wifi is causing all of the issues for us all. I remember reading somewhere that the 2017 LG OLED did not support HFR but the 2018/2019 LG models doesn't seem to either via the internal apps.
daddy
#1049 Post by daddy » Wed Jan 22, 2020 7:08 am
mp4 files are on a DS416J nas.
The LG C7 Player access them in dlna.
deadchip12
#1050 Post by deadchip12 » Wed Jan 22, 2020 8:53 am
No buffering? I tried content sharing between my pc and oled c9 and it keeps buffering.
