Select two language automatically?
kevindery
Post by kevindery »
Can makemkv select two language automatically? Like english and french?
Re: Select two language automatically?
Ideally, being able to prioritize languages would be great.
You CAN do it via default selection settings, assigning specific languages and even given them precedence over each other. But it isn't nearly as easy as picking from a pull-down
Chetwood
Post by Chetwood »
This prioritizes German of English and uses the HD audio track and forced subs are first:
app_DefaultSelectionString="-sel:all,+sel:(deu|eng|nolang),-sel:(core),-10:(forced*(eng)),-15:(deu),-20:(forced*(deu))"
kevindery
Post by kevindery »
Thanks i've take a look at it and it was really easy :)
if anybody want to do it replace "fre" with your second language three letter code
-sel:all,+sel:(favlang|fre),-sel:mvcvideo,=100:all,-10:favlang
kevindery
Post by kevindery »
Chetwood wrote:
Tue Jan 21, 2020 5:26 am
so the order is important for like vlc starting to play the movie in deu and not in eng?
Chetwood
Post by Chetwood »
Not really. If you rip
eng
deu
and flag deu as default yes, players like VLC will play deu instead of eng. But since not all standalones do this I also change to my preferred order
deu
eng
by adding the appropriate weights. Search for 'Changing track order in output file' where this is explained.
