New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
MrTeagan
Post by MrTeagan » Mon Oct 18, 2010 8:46 pm
Predators, Romeo & Juliet and Moulin Rouge contain BD+ and AACS v18. None of them will rip. I assume this requires new SVQ.
Director
setarip_old
Re: New Fox Titles Won't Rip: Predators, Moulin Rouge, etc
Post by setarip_old » Mon Oct 18, 2010 10:42 pm
Hi!
Have you submitted your dumps, so that the .SVQs can be updated?
MrTeagan
Post by MrTeagan » Mon Oct 18, 2010 10:51 pm
Haven't yet because I can't find the address to send them to anymore. I have both.
Director
crowfax
Post by crowfax » Tue Oct 19, 2010 12:26 am
MrTeagan wrote:Haven't yet because I can't find the address to send them to anymore. I have both.
http://makemkv.com/svq/ -> svq@makemkv.com
MrTeagan
Post by MrTeagan » Tue Oct 19, 2010 12:31 am
Emailed!
Director
gmd024
Post by gmd024 » Tue Oct 19, 2010 5:52 pm
I doubt this is of any help with this issue but...I also had trouble ripping the BD of Predators with both versions 158 and 160 -- but after ripping Predators to an unprotected ISO and then mounting it with a virtual drive, I had no trouble ripping it to an MKV with MakeMKV - but of course the encryption is most likely the issue in Predators/MakeMKV and since it was stripped out of the ISO, that's probably why MakeMKV had no issue with the rip then
Hope this helps - if not, please disreguard
setarip_old
Post by setarip_old » Tue Oct 19, 2010 11:16 pm
@gmd024
HOW did you rip "Predators" to "an unprotected iso"?
crowfax
Post by crowfax » Wed Oct 20, 2010 12:11 am
I've sent off the dump file for Predators as well, hopefully it'll be ready soon. Mike also mentioned the 1.6.2 was only a few days away last week, so maybe we'll see that too?
gmd024
Post by gmd024 » Wed Oct 20, 2010 1:05 am
setarip_old wrote:@gmd024
With AnyDVD HD - it plays without issue as a BD/ISO if "Mounted" with Virtual CloneDrive - and of course allows me to rip it in MakeMKV if mounted 1st in VCD - and then plays without issue also after that
gmd024
Post by gmd024 » Wed Oct 20, 2010 1:07 am
With AnyDVD HD - it plays without issue as a BD/ISO if "Mounted" with Virtual CloneDrive - and of course allows me to rip it in MakeMKV if mounted 1st in VCD - and then plays without issue also after that as an mkv
setarip_old
Post by setarip_old » Wed Oct 20, 2010 1:28 am
@gmd024
You are correct - your success with AnyDVD this time around simply means that, this time, the SlySoft guys resolved the "Predators" BD+ coding a little sooner than Mike (will).
If you check the histories of DVDFab (and Passkey), MakeMKV, and AnyDVD, you'll find that they take turns being first resolving protection schemes ;>}
BTW - DVDFab Passkey can also presently properly process the "Predators" Blu-ray disc... (That's a lot of "P's"!)
Post by mike admin » Wed Oct 20, 2010 7:38 am
Moulin Rouge is supported for a while, Predators was just added to SVQ. You might have problems with automatic SVQ download - in this case download the single SVQ manually from http://www.makemkv.com/svq/dsall.svq per instructions at http://www.makemkv.com/svq/dsall.svq
MrTeagan
Post by MrTeagan » Wed Oct 20, 2010 9:10 am
Moulin Rouge doesn't work. Predators now does with the manual SVQ update. No go on Moulin Rouge.
Director
gmd024
Post by gmd024 » Wed Oct 20, 2010 9:31 pm
mike admin wrote:Moulin Rouge is supported for a while, Predators was just added to SVQ. You might have problems with automatic SVQ download - in this case download the single SVQ manually from http://www.makemkv.com/svq/dsall.svq per instructions at http://www.makemkv.com/svq/dsall.svq
Both links take me to the same svq download link - please repost the instructions/link for manual svq install - or does the svq simply get placed in the MakeMKV directory
conttiego
Post by conttiego » Thu Oct 21, 2010 12:47 am
Download the dsall.svq into the makeMKV directory.
Open makeMKV, go to preferences, and look for the BD+ tab.
Point the folder to where the dsall.svq is:
ie C:\program files\makemkv.
It does work for predators.
