DaMacFunkin
#1021 Post by DaMacFunkin » Tue Jan 14, 2020 3:14 pm
rosavanwinkle wrote:
Tue Jan 14, 2020 12:22 am
i just got the quick question of is their a way to convert existing dual layer Dolby Vision mp4's too single layer? i got dvdfab and i don't see anywhere how to do it :/
Author it to a uhd iso or file structure with DVDfab then re-convert back to single layer mp4.
andyy
#1022 Post by andyy » Tue Jan 14, 2020 11:11 pm
Has anyone made a single-layer remux of Rambo: Last Blood with DVDFab? So far I've only made two before; Casino Royale and Gemini Man, both played fine and looked fantastic on my 2019 Philips Android TV with MX Player. I use 1536k E-AC-3 audio on my personal remuxes for maximum compatibility.. Plus my sound system is shit so it doesn't really matter. Anyway, The Rambo remux looked like black and white with green tint with Dolby Vision.. HDR10 version works just fine. Anyone else had issues with this title?
rosavanwinkle
#1023 Post by rosavanwinkle » Wed Jan 15, 2020 3:43 am
Thanks for that info but their is one issue:
Can't do passthrough so it will convert it instead :/ and idk if that will work
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Donpablo80
#1024 Post by Donpablo80 » Wed Jan 15, 2020 10:56 am
I made a single layer of Rambo Last Blood and it plays fine on my LG B7. Made it with DVDFab 11.0.5.1
andyy
#1025 Post by andyy » Wed Jan 15, 2020 1:17 pm
Thanks, I'll re-do it with 11.0.6.5 again and if that doesn't work I'll try downgrading! Sadly my TV can't play dual-layer files, that would be fool proof since we're not 100% sure if DVDFab has properly reverse-enginereed the black magic called Dolby Vision..
Grencola
#1026 Post by Grencola » Wed Jan 15, 2020 5:32 pm
can't you just use Dolby's mp4 demuxer ( https://github.com/DolbyLaboratories/dl ... 64bits.exe ) to extract the 2 hevcs and the ac3 file from your dv mp4 then add them in TSMuxer to make a new m2ts output that you can then add to dvdfab?
DaMacFunkin
#1027 Post by DaMacFunkin » Wed Jan 15, 2020 7:51 pm
Or run your mp4 through mkvtoolnix then add that, I’m sure I did that with Gladiator.
rosavanwinkle
#1028 Post by rosavanwinkle » Thu Jan 16, 2020 3:34 pm
Do you have a guide on how to use it? i'm not so familiar with it
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Jwp860ct
#1029 Post by Jwp860ct » Fri Jan 17, 2020 6:47 am
Angryunibrow wrote:
Sat Dec 28, 2019 7:32 pm
justinadams wrote:
Sat Dec 28, 2019 10:42 am
So i just wanted to do quick write-up about an issue I was having over the past couple of days trying to get Alita: Battle Angel setup and working with yusesope's player.
I was having an issue with mp4box throwing "incomplete box" errors and not playing in yusesope's player(playback failed, error), as if the file was incomplete or corrupted.
come to find out dvdfab had somehow messed up the output. this was discovered by using Mediainfo on the dvdfab output, which showed me "istruncated: yes"
did some more testing with ripping the disc multiple times, in multiple ways, with the same results.
then i noticed the "choose other titles" option in dvdfab. and low and behold there was a whole lot of other streams, several of which where smaller than the full thing.
Went through previewing the titles and they were all(aside from the big main title) parts of the whole.
so as an experiment, I found all the parts to make the whole. and once outputted none were truncated (good sign).
individually tested each file to make sure they worked with yusesope's player, and they did.
then with a little research on mp4box and found the it can actually combine (referred to as concatenates) multiple videos
so with this command and i was able to get the file up and functioning
mp4box -add video1.mp4 -cat video2.mp4 -cat video3.mp4 -cat video4.mp4 output.mp4
Now if you do need to use this make sure you input the files in the correct order.
and so far this has seemed to work just fine.
I could kiss you!
I just tried this and worked perfectly, I didn't watch the entire movie but everything is in sync, I even made a DTS-HD MA 7.1 audio from the Atmos and that sync'd up just fine.
How did you make DTS from Atmos? Is it a command for ffmpeg? Thanks!
Angryunibrow
#1030 Post by Angryunibrow » Sat Jan 18, 2020 12:56 am
I could kiss you!
EAC3TO to make .wav files from the Atmos track, then DTS Master Audio Suite to create the DTS-HD MA file.
DaMacFunkin
#1031 Post by DaMacFunkin » Sat Jan 18, 2020 10:20 am
I could kiss you!
In the scheme of things because you are losing object placement you might as well make a flac file or very high quality 7.1 aac file IMO.
andyy
#1032 Post by andyy » Sat Jan 18, 2020 6:43 pm
I tried with DVDFab 11.0.5.1 and still had the same issue, then upgraded to latest version 11.0.6.8, updated mp4box to the latest version and even tried with another disk since I was starting to doubt the source was corrupted at this point, but even with the latest version and another disk I have the same issue. Man I guess it's got something to do with Philips TVs then, I just wonder how could it be that I only have issues with this specific movie.. Well, I hope it's just Rambo I have issues with, I watched the HDR10 version and the movie was pretty bad anyway :roll: I think I'm just gonna get the Chinoppo to play my Dolby Vision movies with..
DaMacFunkin
#1033 Post by DaMacFunkin » Sun Jan 19, 2020 8:12 am
I have had 3 files that don’t play correctly on my LG c7 and c9 out of the 23 I have converted, those files however play correct on the Shield pro 2019...
Erfero
#1034 Post by Erfero » Sun Jan 19, 2020 8:26 pm
Hi guys, I've got Alida working with Dolby Vision through USB on a philips 804. Plex doesn't recognize dolby vision but only hdr 10 +.
I've simply used mp4muxer muxing BL + EL + audio. The process is slow, even with a nice PC, and even if says "0kb" in reality is working.
Anyway I don't see much difference from an HDR 10 +, is that normal? It looks like this process it's just a fake thing...
Grencola
#1035 Post by Grencola » Mon Jan 20, 2020 4:01 am
that's because, with current displays, hdr10+ is the equivalent to dolby vision. they both offer per-frame specular enhancement over regular hdr10. mp4muxer is definitely not fake as it keeps the seperate layers intact, just like uhd discs; it literally just changes the container. single layer mp4s from DVDFab, however, remain quite questionable at best..
