Unable to read UHD with friendly drives
jcwillia1
Re: Unable to read UHD with friendly drives
Post by jcwillia1 »
I don’t own a 4k pj yet anyways. Was just fooling around to see if it worked.
My 49” uhd tv is not the best use of that technology
jcwillia1
Post by jcwillia1 »
I made a mistake earlier - I have the BC not the BW which I believe should work. Someone posted on AVS (and then had their post erased, mysteriously) that their same drive (Asus BC-12B1ST) with 3.00 firmware worked
Problem is I can't seem to locate 3.00 firmware for that drive. and the Asus page shows 3.01 available.
Is the BW-16D1HT firmware cross compatible?
st4evr
Post by st4evr »
The only difference between the BC snd BW is the packaging. One is the OEM and the other is the RETAIL.
IT’S THE SAME DRIVE.
As you’ve been told before (viewtopic.php?f=16&t=17223&p=64927&hilit=12B1ST#p64927), it’s listed INCORRECTLY as a friendly drive. That post “disappeared” most likely because the author realized he was talking out of his ass. Stop beating this dead horse and buy a proper friendly drive if you want to rip UHD BDs.
Going down the path you are thinking you will most likely brick your drive and only bring on even more frustration and confusion upon yourself. Stop while you’re ahead and get a proper drive.
jcwillia1
Post by jcwillia1 »
Thanks for the encouragement
Deniska
Post by Deniska »
I have old BW-16D1HT c firmware 1.01 how to upgrade it for UHD disc? Are there variants now?
Post by SamuriHL »
You don't. Attempting to will brick the drive. It's too old.
