Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: XXX
Bus encryption flags: 1F
Highest AACS version: 65
Firmware version: 3.10
So I grabbed more discs:
FMW Total Carnage - audio is fine
MakeMKV v1.14.7 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '1048576'
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Complex multiplex encountered - 15 cells and 7212 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (15 cell(s), 1:52:00)
Title #2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 1 cells and 160 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #7 was added (1 cell(s), 0:02:28)
Complex multiplex encountered - 1 cells and 474 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #8 was added (1 cell(s), 0:07:22)
Complex multiplex encountered - 1 cells and 194 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #9 was added (1 cell(s), 0:03:00)
Title #10 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 4 titles into directory E:/Data/DVD/TOTAL_CARNAGE
4 titles saved
Title #1 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 was added (17 cell(s), 1:20:04)
Title #3 was added (17 cell(s), 1:20:04)
Title #4 was added (2 cell(s), 0:02:00)
Title #5 was added (2 cell(s), 0:02:00)
Title 2 in VTS 2 is equal to title 1 and was skipped
Title 2 in VTS 3 is equal to title 1 and was skipped
Saving 2 titles into directory E:/Data/DVD/STACY
2 titles saved
Title #00003.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
Title #00005.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #1
Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory E:/Data/DVD/God Of Gamblers
AV synchronization issues were found in file 'God Of Gamblers_t00.mkv' (title #1)
Forced subtitles track #2 turned out to be empty and was removed from output file
2 titles saved
