The newer versions have a huge drawback for me:
Whenever you start a new makemkv instance while using two BD drives the drive that is in use is being interrupted. There is no way to select the drives in advance as it used to be. I hope this will be fixed (MAC).
Selecting BD drive for new instance not possible
ESPNY
Re: Selecting BD drive for new instance not possible
This should apply to the Mac version, as well?
Check 'Ask for single drive mode' under Preferences > IO tab.
ESPNY
Thanks, that solved it. Just confused by the term single drive mode for multiple drives!
