MEG UHD - Failed to open disc
BLUTigerOB
Post by BLUTigerOB » Tue Jan 14, 2020 10:01 pm
Hallo guys,
I cannot rip or open the MEG UHD. The following error is displayed. Can someone help me.
Saved AACS dump file as C: ... \MKB20_v66_The_Meg_2CEB.tgz
Failed to open dość
Thanks for your help!
Re: MEG UHD - Failed to open disc
Post by Woodstock » Wed Jan 15, 2020 12:15 am
Have you sent the dump file to svq@makemkv.com yet?
BLUTigerOB
Post by BLUTigerOB » Wed Jan 15, 2020 4:58 pm
Yes I sent it at the same time yesterday. How long will it take?
Post by Woodstock » Wed Jan 15, 2020 6:19 pm
People have usually reported being able to rip disks within a day or so of submitting the dump file via email.
BLUTigerOB
Post by BLUTigerOB » Wed Jan 15, 2020 9:46 pm
I hope so. Thx for your support.
BLUTigerOB
Post by BLUTigerOB » Thu Jan 16, 2020 8:12 pm
Did I have any other options if I don't get a reply to my email?
st4evr
Post by st4evr » Thu Jan 16, 2020 8:29 pm
No one ever gets a response when submitting the required dumps for key support. We all just have to wait for them to be added to the database.
BLUTigerOB
Post by BLUTigerOB » Thu Jan 16, 2020 9:12 pm
Thanks for this information.
BLUTigerOB
Post by BLUTigerOB » Fri Jan 17, 2020 9:02 pm
How can I update the database?
Post by d00zah » Fri Jan 17, 2020 9:41 pm
It's automatic. Assuming you have "Allow contacting web server for updates" checked on the General preferences tab, a check for SDF/HK updates is performed on MakeMKV startup & updates are reported in the status pane.
BLUTigerOB
Post by BLUTigerOB » Fri Jan 17, 2020 10:19 pm
Okay thanks. The settings are correct but it still doesn't work. Then just waiting helps.
