MEG UHD - Failed to open disc
BLUTigerOB
Hallo guys,
I cannot rip or open the MEG UHD. The following error is displayed. Can someone help me.
Saved AACS dump file as C: ... \MKB20_v66_The_Meg_2CEB.tgz
Failed to open dość
Thanks for your help!
Failed to open dość
Re: MEG UHD - Failed to open disc
Have you sent the dump file to svq@makemkv.com yet?
BLUTigerOB
Yes I sent it at the same time yesterday. How long will it take?
People have usually reported being able to rip disks within a day or so of submitting the dump file via email.
BLUTigerOB
I hope so. Thx for your support.Woodstock wrote: Wed Jan 15, 2020 6:19 pm People have usually reported being able to rip disks within a day or so of submitting the dump file via email.
BLUTigerOB
Did I have any other options if I don't get a reply to my email?
st4evr
No one ever gets a response when submitting the required dumps for key support. We all just have to wait for them to be added to the database.BLUTigerOB wrote: Thu Jan 16, 2020 8:12 pm Did I have any other options if I don't get a reply to my email?
BLUTigerOB
Thanks for this information.st4evr wrote: Thu Jan 16, 2020 8:29 pmNo one ever gets a response when submitting the required dumps for key support. We all just have to wait for them to be added to the database.BLUTigerOB wrote: Thu Jan 16, 2020 8:12 pm Did I have any other options if I don't get a reply to my email?
BLUTigerOB
How can I update the database?st4evr wrote: Thu Jan 16, 2020 8:29 pmNo one ever gets a response when submitting the required dumps for key support. We all just have to wait for them to be added to the database.BLUTigerOB wrote: Thu Jan 16, 2020 8:12 pm Did I have any other options if I don't get a reply to my email?
It's automatic. Assuming you have "Allow contacting web server for updates" checked on the General preferences tab, a check for SDF/HK updates is performed on MakeMKV startup & updates are reported in the status pane.
BLUTigerOB
Okay thanks. The settings are correct but it still doesn't work. Then just waiting helps.d00zah wrote: Fri Jan 17, 2020 9:41 pmIt's automatic. Assuming you have "Allow contacting web server for updates" checked on the General preferences tab, a check for SDF/HK updates is performed on MakeMKV startup & updates are reported in the status pane.
