Krawk
#1006 Post by Krawk » Thu Jan 09, 2020 10:38 pm
Can we get a summary of all the discoveries on the original post?
I appreciate all the back and forth on this topic, but if one were new to this thread, there is a lot of reading and some information that might not work. If the original post were updated this would be FANTASTIC!
DaMacFunkin
#1007 Post by DaMacFunkin » Fri Jan 10, 2020 6:57 am
Krawk wrote: Thu Jan 09, 2020 10:38 pm Can we get a summary of all the discoveries on the original post?
https://forum.mrmc.tv/viewtopic.php?f=1 ... 310#p25425 This post is all you need really at this moment in time, if you want more than this provides then you deserve to go and read up on specifics.
box4m
#1008 Post by box4m » Fri Jan 10, 2020 3:39 pm
DaMacFunkin wrote: Thu Jan 09, 2020 9:51 pm I don’t use MX player, I find it ropey, use Plex or MrMC.
since when does mrmc work?
DaMacFunkin
#1009 Post by DaMacFunkin » Sat Jan 11, 2020 7:19 am
box4m wrote: Fri Jan 10, 2020 3:39 pm
I don’t know? I believe it always worked on the Firestick before The Shield pro 2019 came out, just checked it, it works.
box4m
#1010 Post by box4m » Sat Jan 11, 2020 1:37 pm
DaMacFunkin wrote: Sat Jan 11, 2020 7:19 am
Works on the firestick or shield? If its the shield, are you sure its not HDR10
DaMacFunkin
#1011 Post by DaMacFunkin » Sat Jan 11, 2020 3:46 pm
box4m wrote: Sat Jan 11, 2020 1:37 pm
Works on the shield, my LG C9 says Dolby Vision not HDR...
The guide that most people use is from the MrMC forum, why do you find it hard to believe that it works on MrMC? As far as I understand it has worked on MrMC for over a year (on the fire stick 4K) obviously the shield 2019 has only been out for 3 months.
kennedy88
#1012 Post by kennedy88 » Sat Jan 11, 2020 6:15 pm
piidii wrote: Thu Jan 02, 2020 1:37 pm
Grencola wrote: Wed Jan 30, 2019 7:54 pm
Fuso90 wrote: Wed Jan 30, 2019 6:05 pm
I've just tried that but nothing happens. It starts to write to my HDD, creates the file movie.mp4, after ~15 mins the cmd prompt closes and the output file movie.mp4 is 0 bytes in size...
oh oops, thx for pointing this out, I edited my original post. put this in startmux.cmd instead:
ren *.hevc baselayer.hevc
ren 0*.hevc dvlayer.hevc
ren *.ac3 audio.ac3
mp4muxer_64bits.exe --dv-profile 7 --input-file baselayer.hevc --input-file dvlayer.hevc --input-file audio.eac3 --media-lang eng --output-file movie.mp4
I have exactly the same problem. Still 0 kB. If i close CMD after while it will have a size 1 kB. I really dont know what im doing wrong. Can you help me please? Im trying that on Windows 10. Thank You!
Same problem :(
daddy
#1013 Post by daddy » Sun Jan 12, 2020 9:51 am
ren *.ac3 audio.ac3
for ac3 audio the file need to be .ac3 extension
mp4muxer_64bits.exe --dv-profile 7 --input-file baselayer.hevc --input-file dvlayer.hevc --input-file audio.ac3 --media-lang eng --output-file movie.mp4
for eac3 audio the file need to be .ec3 extension
mp4muxer_64bits.exe --dv-profile 7 --input-file baselayer.hevc --input-file dvlayer.hevc --input-file audio.ec3 --media-lang eng --output-file movie.mp4
bgalakazam
#1014 Post by bgalakazam » Mon Jan 13, 2020 6:34 pm
Just a recap since I haven't actively followed the thread.
- If I want DV + Atmos I need to use yusesope's server and apk which mandates a device that you can install apk like a Shield?
- Does the app work with dual layer DV?
- I also have a FireTV 4K stick. That doesn't do lossless audio so what's the use case for this? OLED TVs already playback these mp4s.
- MPC-BE with LAV filters bitstreams Atmos TrueHD, but HTPC doesn't do DV over HDMI to receiver, correct?
I am fully comfortable with the muxing and converting process, my main question remains what is a method to run DV with TrueHD Atmos? I still have my C8 and X700, no Shield.
Sony X700 -> Onkyo TX-RZ830 -> LG C8
rosavanwinkle
#1015 Post by rosavanwinkle » Tue Jan 14, 2020 12:22 am
i just got the quick question of is their a way to convert existing dual layer Dolby Vision mp4's too single layer? i got dvdfab and i don't see anywhere how to do it :/
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
DaMacFunkin
#1016 Post by DaMacFunkin » Tue Jan 14, 2020 3:14 pm
rosavanwinkle wrote: Tue Jan 14, 2020 12:22 am i just got the quick question of is their a way to convert existing dual layer Dolby Vision mp4's too single layer? i got dvdfab and i don't see anywhere how to do it :/
Author it to a uhd iso or file structure with DVDfab then re-convert back to single layer mp4.
andyy
#1017 Post by andyy » Tue Jan 14, 2020 11:11 pm
Has anyone made a single-layer remux of Rambo: Last Blood with DVDFab? So far I've only made two before; Casino Royale and Gemini Man, both played fine and looked fantastic on my 2019 Philips Android TV with MX Player. I use 1536k E-AC-3 audio on my personal remuxes for maximum compatibility.. Plus my sound system is shit so it doesn't really matter. Anyway, The Rambo remux looked like black and white with green tint with Dolby Vision.. HDR10 version works just fine. Anyone else had issues with this title?
rosavanwinkle
#1018 Post by rosavanwinkle » Wed Jan 15, 2020 3:43 am
DaMacFunkin wrote: Tue Jan 14, 2020 3:14 pm
Thanks for that info but their is one issue:
Can't do passthrough so it will convert it instead :/ and idk if that will work
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Donpablo80
#1019 Post by Donpablo80 » Wed Jan 15, 2020 10:56 am
andyy wrote: Tue Jan 14, 2020 11:11 pm Has anyone made a single-layer remux of Rambo: Last Blood with DVDFab? So far I've only made two before; Casino Royale and Gemini Man, both played fine and looked fantastic on my 2019 Philips Android TV with MX Player. I use 1536k E-AC-3 audio on my personal remuxes for maximum compatibility.. Plus my sound system is shit so it doesn't really matter. Anyway, The Rambo remux looked like black and white with green tint with Dolby Vision.. HDR10 version works just fine. Anyone else had issues with this title?
I made a single layer of Rambo Last Blood and it plays fine on my LG B7. Made it with DVDFab 11.0.5.1
andyy
#1020 Post by andyy » Wed Jan 15, 2020 1:17 pm
Donpablo80 wrote: Wed Jan 15, 2020 10:56 am
Thanks, I'll re-do it with 11.0.6.5 again and if that doesn't work I'll try downgrading! Sadly my TV can't play dual-layer files, that would be fool proof since we're not 100% sure if DVDFab has properly reverse-enginereed the black magic called Dolby Vision..
