Quantum Leap - BR - Season 2 E1 & 5, Season 4 E2 & 4
9Nails
Post by 9Nails » Mon Jan 13, 2020 4:29 am
I'm having troubles copying these episodes from new Blu-Ray discs. I returned the collection to the store and exchanged the discs with a new set. And I'm running into the same error. I tried two different BR drives, and two different computers. I also tried to copy the disc as an ISO to my computer, but I'm having technical difficulties with that as well. Seems that these read errors can cause the drive to lock up. 2 different blu ray disc sets, same errors. Any suggestions?
MakeMKV v1.14.7 win(x64-release) started
Using LibreDrive mode (v05 id=64754CF46FCA)
File 00007.mpls was added as title #0
File 00006.mpls was added as title #1
File 00005.mpls was added as title #2
File 00004.mpls was added as title #3
File 00003.mpls was added as title #4
Title #00008.m2ts has length of 30 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00002.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00001.m2ts has length of 15 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 2 titles into directory P:/TV Shows/Quantum Leap/Season 2 (1990)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '7832076288'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7832076288'
Failed to save title 0 to file P:/TV Shows/Quantum Leap/Season 2 (1990)/Quantum Leap s02e05.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '464781312'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '464781312'
Failed to save title 4 to file P:/TV Shows/Quantum Leap/Season 2 (1990)/Quantum Leap s02e01.mkv
Encountered 43 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 2 failed
9Nails
Re: Quantum Leap - BR - Season 2 E1 & 5, Season 4 E2 & 4
Post by 9Nails » Mon Jan 13, 2020 8:58 pm
TL;DR: I used AnyDVD top rip the videos to hard drive. Then used MakeMKV to put them into MKV files. Problem solved for this disc.
Details:
The shows in question played back fine in my PlayStation 4 drive as a Blu Ray disc. I was getting frustrated that I could watch the disc, but not shift it's format so that I can watch it from my Plex server. I tried a few programs to preform data recovery on the disc(s). RecoverIt, Unstopable Copy, ISO Buster... etc... to see if I can back it up to ISO or even as files on a hard drive. At times it seemed like these programs were crashing, and I'd need to reboot or unplug my drive from the USB port. I tried multiple drives, computers, and even exchanged the disc with the store. I tried MakeMKV's backup to hard drive feature, with the "Decrypt video files" option unselected. These all failed in some way. They each had varying problems, and that might be due to copy protection. I even resorted to downloading some torrent files from a DVD rip, but I wasn't happy with that. The shift from HD to DVD for 2 or 3 shows in a series was undesired.
So I downloaded AnyDVD 8.4.4.0 from Slysoft. Installed and reboot. Near my Computer's clock is a Fox icon for AnyDVD, I right-clicked that and selected the "Rip Video Disk to Hard Disk" feature. I pointed it to my Blu Ray drive with the "bad" disc and told it where to save the files. No complaints about reading the files from the disc! The files were put into Blu Ray file folders with names such as:
D:\
...QUANTUM LEAP S2D1\ (my root folder from the Blu Ray disc)
...0012FA\ (Contains disc.bbd and \BACKUP\disc.bbd)
...BDMV\ (Contains movie / TV show files)
...CERTIFICATE (Contains id.bdmv and BACKUP\id.bdmv)
disc.inf
D: is a 1TB WD easystore hard drive on a USB port for my computer by the way.
Next I ran MakeMKV. I selected, File / Open files (Ctrl + O) and selected D:\QUANTUM LEAP S2D1\BDMV\index.bdmv.
MakeMKV processed the index faster than I've ever seen before (because it's on a hard drive now) and showed me a lit of titles. So far so good, but we've been here many times. Time to cross my fingers and move on.
I selected all the titles that I wanted, and the output folder - which is the same as the source in my case, and pressed the "Make MKV" button.
That worked! I don't know if AnyDVD has a better backup to disc option than MakeMKV, or if I should have selected the decrypt option when backing up with MakeMKV. Or if AnySoft's copy protection is working better and broke the file encryption that was causing these errors. But the end result is that I was able to copy the TV shows, so I'm happy.
DataMeister
Post by DataMeister » Sat Dec 16, 2023 6:53 pm
I'm seeing the same or a similar problem and here we are on v1.17.5. Seems like different episodes in S2 that aren't reading though. I wonder why AnyDVD would be able to read the disc, in your case, but MakeMKV couldn't? Perhaps MakeMKV could develop some alternate read methods for problem discs like this.
