Multiple Instance Ripping?
camelotbob
Post by camelotbob » Wed Jan 08, 2020 1:45 pm
I see that MakeMKV can have more than one instance running on Windows 10. Can it rip multiple discs simultaneously?
Re: Multiple Instance Ripping?
Post by Woodstock » Wed Jan 08, 2020 1:46 pm
Yes.
camelotbob
Post by camelotbob » Wed Jan 08, 2020 4:54 pm
Thanks much @Woodstock.
Post by d00zah » Wed Jan 08, 2020 8:35 pm
To facilitate this, check "Ask for single drive mode" on the IO preferences tab. This asks you to assign a specific optical drive to each instance of MakeMKV & avoids conflicts.
camelotbob
Post by camelotbob » Wed Jan 08, 2020 10:37 pm
Thanks for this info as well @d00zah.
mkvfanclub
qqq qqq qqq qqq qqq
Post by mkvfanclub » Sun Jan 12, 2020 9:58 pm
qqq qqq qqq qqq qqq
mkvfanclub
qqq qqq qqq qqq qqq
Post by mkvfanclub » Mon Jan 13, 2020 9:50 am
qqq qqq qqq qqq qqq
biospot
Post by biospot » Fri Feb 14, 2020 8:47 pm
Hm...
I use handbrake as well, but I don't use it to rip. MakeMKV runs my 4 drives in parallel and all 4 drives are the same speed as 1 drive to complete, so I can complete my rips 4 times faster with MakeMKV then I could with Handbrake.
Since there is no processing the processor limits don't apply and while ripping 4 instances my computer is running 5-10% using MakeMKV. Of course if you want to rip and re-encode at once Handbrake may be better, but I want to separate those so I rip first then later, I run handbrake as you suggest.
wrldtvlr
Post by wrldtvlr » Sun Feb 16, 2020 6:41 pm
This is really important and makes life much easier. Otherwise there can be thrashing while the second instance of MakeMKV attempts to read the disc from the first instance which can lead to the first instance failing.
camelotbob
Post by camelotbob » Mon Feb 17, 2020 3:23 pm
This is one heck of a selling point!
glonch
Post by glonch » Sat Mar 14, 2020 6:12 pm
Follow on question to this thread...
I have 8 optical drives in my system and MakeMKV does an awesome job ripping DVDs and BDs from them.
Is there a way to run a batch file (or similar) to have Windows 10 open 8 MakeMKV GUI instances, each assigned to a unique drive?
