Multiple Instance Ripping?
camelotbob
Post by camelotbob »
I see that MakeMKV can have more than one instance running on Windows 10. Can it rip multiple discs simultaneously?
Re: Multiple Instance Ripping?
Yes.
camelotbob
Thanks much @Woodstock.
Post by d00zah »
camelotbob wrote:
Wed Jan 08, 2020 1:45 pm
To facilitate this, check "Ask for single drive mode" on the IO preferences tab. This asks you to assign a specific optical drive to each instance of MakeMKV & avoids conflicts.
camelotbob
Thanks for this info as well @d00zah.
mkvfanclub
qqq qqq qqq qqq qqq
Post by mkvfanclub »
qqq qqq qqq qqq qqq
mkvfanclub
qqq qqq qqq qqq qqq
qqq qqq qqq qqq qqq
biospot
Post by biospot »
Hm...
I use handbrake as well, but I don't use it to rip. MakeMKV runs my 4 drives in parallel and all 4 drives are the same speed as 1 drive to complete, so I can complete my rips 4 times faster with MakeMKV then I could with Handbrake.
Since there is no processing the processor limits don't apply and while ripping 4 instances my computer is running 5-10% using MakeMKV. Of course if you want to rip and re-encode at once Handbrake may be better, but I want to separate those so I rip first then later, I run handbrake as you suggest.
wrldtvlr
Post by wrldtvlr »
d00zah wrote:
Wed Jan 08, 2020 8:35 pm
This is really important and makes life much easier. Otherwise there can be thrashing while the second instance of MakeMKV attempts to read the disc from the first instance which can lead to the first instance failing.
camelotbob
biospot wrote:
Fri Feb 14, 2020 8:47 pm
This is one heck of a selling point!
glonch
Post by glonch »
Follow on question to this thread...
I have 8 optical drives in my system and MakeMKV does an awesome job ripping DVDs and BDs from them.
Is there a way to run a batch file (or similar) to have Windows 10 open 8 MakeMKV GUI instances, each assigned to a unique drive?
