Multiple chapters for Bluray & HD DVD?
vinomarky
#1 Post by vinomarky » Sat May 30, 2009 5:38 am
Hi there,
I have used this nice tool successfully one one of my Blurray disks, but when I tried it one one of my HDDVD disks, it just came up with 20-30 smaller chapters which were saved as seperate video files - not one of these chapters was even 1GB, let alone the expected 7GB+
I wrote this off as problems with HDDVD support
Today, I just tried with a new Bluray disk, and have the save problem - only one of the chapters exceeds 1GB in size (and only just)
Is there a trick here? I don't see any obvious way to tell MakeMKV to concatenate a bunch of chapters into one file...
Any help appreciated!
Ta
Edit: I have MakeMKV v1.4.2 installed, and am converting with AnyDVD 6.5.5.5 doing the background decrypting
Re: Multiple chapters for Bluray & HD DVD?
#2 Post by mike admin » Fri Jun 05, 2009 7:11 am
HD-DVD support is limited and is likely to stay this way. I would suggest using eac3to for hd-dvd conversion.
vinomarky
#3 Post by vinomarky » Sat Jun 06, 2009 2:24 pm
Thanks for the reply - I pretty well realized that about HD DVD support, but the main problem is that I have issues with MakeMKV not being able to identify a single main-movie section for Blurays....
#4 Post by mike admin » Tue Jun 09, 2009 6:08 am
What kind of disc is that? MakeMKV should be able to concatenate all chapters together w/o any problems.
vinomarky
#5 Post by vinomarky » Sat Jun 13, 2009 7:34 am
Thanks - I took a screen grab of how MakeMKV is interpreting the chapters, and in the process realized that it was in fact working - I must have skimmed over the 15+GB chapter, thinking it was 15mb.....
Thanks anyway - seems to be fine.
