qqq qqq qqq qqq qqq
mkvfanclub
qqq qqq qqq qqq qqq
qqq qqq qqq qqq qqq
Grauhaar
Re: Enter output folder name before initial scan
Have you checked under perferences -> "Video" the "Semi Auto" option which uses automaticaly the disc name as the folder name ...? I like this feature
Good Luck
mkvfanclub
qqq qqq qqq qqq qqq
qqq qqq qqq qqq qqq
Grauhaar
Hmm, I think you are alone with your "problem"
Yes, some series uses a generic name, but you can override it by appendig an 1 or 2 oder whatever. I've never had a problem with this and I use two drives and can remember what disc is in drive 1 or 2.
Good Luck
