qqq qqq qqq qqq qqq
mkvfanclub
qqq qqq qqq qqq qqq
Post by mkvfanclub »
qqq qqq qqq qqq qqq
Re: Custom filenames
You can set up a file naming template if you have Expert mode enabled. It's on the Advanced tab of preferences.
Also, if you modify the the "name" field while the top level of the disk selected in the left window, MakeMKV will cascade that to all tracks that have not been manually changed.
